LS1 performance mods
Old Oct 11, 2016 | 12:46 PM
Thomas Hancock's Avatar
Default LS1 performance mods
I have a 2000 LS S Z28 that I want to build up. What are people doing or have done? Texas Speed had a nice 383 stroker kit. Thoughts?
Old Oct 11, 2016 | 12:49 PM
JoeNova's Avatar
Restricted User
Cam, headers, tune.
Old Oct 11, 2016 | 01:08 PM
Aaron at SDPC's Avatar
Really depends on budget and intended use. Does the car currently have any mods? Is the car an automatic or six speed?
Old Oct 11, 2016 | 01:18 PM
farmington's Avatar
if your shortblock is in decent shape, heads, cam, intake, exhaust, and tune can get you well into the 11's while still retaining streetability. How fast do you want to go?
Old Oct 11, 2016 | 01:22 PM
Default 6 speed
No mods.
Old Oct 11, 2016 | 01:23 PM
Originally Posted by Thomas Hancock
No mods.
Intended use? Is it an automatic or manual transmission?
Old Oct 11, 2016 | 01:26 PM
yeah that's what I have been looking at. Curious to see what others have done and get opinions before making this decision. Just want to make sure I make the right choice.
Old Oct 11, 2016 | 01:27 PM
6 speed
Old Oct 11, 2016 | 01:29 PM
It's for fun. Want to enjoy track days. And want a bad *** ride that's rowdy.
Old Oct 11, 2016 | 01:32 PM
There a lot of different directions to go. If the car is completely stock I would consider installing an aftermarket lid, and longtube headers to start. Then beyond that a camshaft swap, and gear change. Keep in mind though with a stock 10-bolt rear you will be on borrowed time if you plan on putting a sticky tire on it and getting aggressive with launches. Of course something else to consider as you start to make more power is a clutch swap.
Old Oct 11, 2016 | 01:37 PM
Frankenstein's Avatar
Most starts usually begin with the following (budget depending of course):
1) LS6 intake
2) Longtube Headers
3) Cam
4) Heads
5) Y-pipe or True-Dual setup/muffler
6) Suspension
7) Gears
8) Tires
9) Clutch
10) Rear (9" or 12 bolt, most common swaps)
Never ending list really haha. Do you plan to stay N/A or introduce a power adder to your application?
-Russ
Aaron gets it!
-Russ
Old Oct 11, 2016 | 01:39 PM
Originally Posted by Frankenstein
Aaron gets it!
-Russ
Thanks Russ!
Old Oct 15, 2016 | 10:35 PM
Mazzenger's Avatar
Lid, Cam, Springs, Headers, 3 Inch Exhaust, Cut-outs, new clutch and a 125 wet shot.
Launch easy until you can get a stronger rearend.
I had a friend put in decent cam, Lid and headers and trap 120 w/M6 SS. All else stock.
I had another friend put in 125 wet shot and trap 122 w/M6 TA. - All else stock
