Intake valves...2.00, 2.02, 2.04? Stock LS1 w/ big cam
Port velocity, port volume, chamber design, valve job, valve size, exhaust port efficiency (way overlooked in my opinion) etc. all play part in what makes a head great or a turd. If one of those aforementioned is not optimized for the "combination", then results will suffer. AI has proved you don't need oversized intake valves to make great power.
I have the PRC Stage 2.5 5.3 heads and a custom Comp Cam .588/232 intake .600/238 exhaust. Stock LS1 bottom end 1.75 headers, LS6 intake. ORY single exhaust. Ran 11.96 @ 115 at 1100ft above sea level in a car that weighs 3875lbs with my fat self in the seat.
There are better combo's. But for the money the PRC heads are hard to beat.
