rolled donor car what needs cleaning? seafoam on the cylinder?
picked up a rolled 2000 silverado.
I wanted to check to see how it runs first before pulling it out for a swap.(also interested if the transmission is good by driving it in my driveway. (atleast i would know if it works in R/D.)
Finally had a chance to start it up. smoked a bunch as expected i havent done any cleaning just checked the fluids and filled the oil. also sprayed electronic cleaner on the maf.(there was oil there)
It starts but kept on dying.at times i can keep the car running but eventually dies(i figured tons of oil in the intake or other sensor.)
good news is it runs and no knock or wierd engine noise.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
now i can plan for a mini tear down for cleaning the intake track and where ever else the oil could have gotten too. I want the engine running great before i pull it out that way i wont be chasing my tail later- it will be a retrofit so custom harness too.)
in your experience what needs cleaning on a rolled vehicle?
does injectors gets clog? i know ill be cleaning the intake so thats coming off.
do i need to seafoam the cylinder?(i dont plan on pullng the heads just through the spark plug hold-spray it, let it sit and start it up after a day or something)
im hoping once everything is clean it will hold idle and be all ok
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
