What to check?
Old Oct 22, 2016 | 09:27 PM
chevybayboy's Avatar
Default What to check?
Hello fellas , was a nic3 day decided to take the car out for a spin. Got on it a little to about 4500 RPM max. Now the car is misfiring or something, it's definitely not running on all cylinders was running perfect before they pulls. I'M RUNNING plugs 3346 ngk br7ef put a scanner on the car no engine codes. I changed the plugs nothing still doing the same thing. It's rough in the lower RPM range taking off but isn't so bad when you get past 2k RPM where should I start?
Old Oct 22, 2016 | 09:31 PM
xdanny510x's Avatar
Check ur cam sensor or crank sensor...and coils
And the car backfires like crazy
Old Oct 22, 2016 | 09:32 PM
Shouldn't a ASE code pop up for those?
Old Oct 22, 2016 | 10:25 PM
Ok changed out ignition coils, still same thing.
Old Oct 23, 2016 | 07:36 AM
RockinWs6's Avatar
I'd check the cam timing, chain may have jumped over the sprocket.
Old Oct 23, 2016 | 08:33 AM
That's true. I'm going to hook a fuel pressure gauge up. It would be pretty hard for it to jump i have the chain guides in there.
Old Oct 23, 2016 | 12:26 PM
Found the culprit
