Windage Tray: necessary?
SURE, I baited/hooked MANY here with the "panless" engine report, a TRUE REPORT !
This test was a REQUIRED test to PROVE to Dick Moroso that HIS Oil Pan/Scraper design was NOT PERFECT.
MANY here will spend 3K dollars on heads/cams/etc. for 20 EXTRA HP, then NO Money on a good windage/scraper tray that would cost LESS THAN $100.00 providing the SAME increase in HP.
Lance
The windage tray in most every LS engine has built in louvers that act much like a scraper (in theory), allowing the tumbling “oil cloud” to exit the area around the crank at rpm.
Are you saying that I can purchase a BETTER tray, that will give me 20 hp? For less than $100?
