H/C/I build need validation on cam choice
Old Nov 29, 2016 | 04:40 PM
z-maro's Avatar
Originally Posted by 01ssreda4
I have the 226cc 799s, and no dyno graph but it runs high tens on motor.
You have quite a bit of weight reduction though.
Well I took advantage of Goeff's holiday special pricing and went with his 226/230 113+3 .604/.604. After discussing with Geoff I also decided to go with the stock MLS head gasket. I should be right around 11:1 for the compression ratio. I'll probably start a build thread on here for anyone that cares, and to share all the part numbers I got for a full H/C/I swap.
Originally Posted by kinglt-1
3.42's and a 6 speed is damn near as bad as 2.73's in a auto with stock stall...ok not really that bad but you are leaving a lot on the table with that gearing and any performance cam. Put a 3.90 in it and don't do hard launches and you will be fine.
I agree.
Gears will do more to make this a fun car for Z-camaro to drive than worrying about which 222/226 sized cam vs 228/232 sized cam. For fun driving in a six speed 4th Gen LS1 car 4.10's are nearly perfect in my experience. 3.73's are also excellent. I would think 3.90's would be very good too.
While there might be a rare six speed 4th Gen F-car with with a 220/220 plus size cam that drives OK with 3.42 gears, there is no doubt those same cars would be even more fun to drive with 3.73's or better gears.
I've rode in several six speed 4th Gen's that were lousy drivers with 224ish sized cams and stock 3.42 gears. These cars needed to hit 75-80 mph to stay in 6th gear and not buck/surge. Some of it could have been mediocre tuning but for the most part these cars just needed to turn more rpm to drive 'nice' in 6th gear at 60 mph.
My TA drives very 'nice' shifting to 6th gear around 45 mph with the 4.10's and the H&C in sig. The with the 4.10 gears the TA drives better and easier than stock in all traffic situations except when creeping along under a 1000 rpms going uphill in a parking deck/garage.
A good set of gears will easily make up for any power lost under 3000 rpms for about any of these low 230ish sized cams.
I'll see how it goes with the 3.42's and go from there, but sounds like an upgrade to 3.90's would be nice to down the road. Just have to decide if it would be in the 10 bolt or go to a 12 bolt/8.8"/9".
Thanks everyone for the help on the cam decision. I already have the motor partly torn down with the rest of the required parts in the mail.
Old Nov 30, 2016 | 01:23 AM
silvershark's Avatar
Great cam choice! Exactly what I would have done if I was in your shoes, but would have went with a 112 LSA! Let us know what you think!
I went with a 115LSA, Geoff recommended a 114 LSA or even a 113 LSA for my car because I wanted the torque down low as well... Wish I would have listened, but I was scared with an auto on the stock stall with a 113/114 LSA and tuning it to idle correctly.
I am not disappointed, but I imagine I could have gained some better torque lower in the rpm range if I kept my stock stall and went with a 112/113 LSA "if i could get the car to idle correctly". Since I moved to a higher converter, I think I will be tickled. He recommended a 115 LSA for my small cam if I got a converter. I figured I was going to get a converter at some time, I just didn't think it would be a few months after putting the cam in.
Your in VERY good hands.
Old Nov 30, 2016 | 09:49 PM
00pooterSS's Avatar
That advance in the cam helps shift things down lower too. I learned that many years ago when I drove a friends Altima with the 3.5 V6 and the timing was off (something failed) it was advanced and that car ran its *** off from idle to about 4500 or so rpm and then it would fall flat on its face. It was a torque monster, it was hilarious, wish I had video.
Old Dec 1, 2016 | 09:30 AM
01ssreda4's Avatar
Yeah Ive been in a Neon that had its cam a few degrees back and it was a dog off the line but man it would fly once you got the rpms up.
Old Dec 3, 2016 | 11:50 AM
z-maro's Avatar
It won't be till spring but I will report back with my thoughts.
I went with the Cloyes Hex-Adjust timing set so I could degree it in. Geoff thought installing it dot to dot would be sufficient but for any precision install to go degree it. I still haven't decided what I'm gonna do.
