Considering a cam
So, I would recommend:
The Cam Motion Titan IV camshaft
New Lifters
New Lifter Trays
Our .650" or .660" valve springs kit
Our hardened chrome-moly .080" wall pushrods in 7.400"
A new timing chain set
New Melling 10295 Oil pump:
New Harmonic Damper Bolt
The easiest way to create a camshaft installation kit and see the cost total in real-time is to use our Camshaft Installation Kit Creator:
http://store.cammotion.com/customize...roller-cam-kit
This one page has every option you might need to install your camshaft. Simply choose each item you are considering and add to the shopping cart. You can even refine your choices once it is in the shopping cart and see your kit total price change in real time. So much easier than hunting down all the parts on different pages. Try it out.
I do wish I had a shop so I could pull the motor and refresh the bottom end too.
I've had other folks tell me on here that since I have 3:23 gears and I'm an auto that going to 3:73 gears won't gain me much. But maybe that was before I ever considered a cam.
The other option is nitrous instead of the heads. I'd still do the cam and upgrade the top end. It'll make the nitrous work better. And a budget nitrous setup is about the cost of budget heads. And you can add 150 shot without much issue. And that should drop well over a second off your ET at this speed. Cam + 150 shot would work with your converter as well. And you'd be into the 10s.
For example...I use a GTECH meter to measure gains on mods I have done to my car on the street. It has always been within a tenth of the track for accuracy, the caveat being a unprepped street is much harder to launch. I had my Bolt-on setup running 12.2 @ 119. did the H/C/I swap and ended up slowing down ET wise but picked up 6 mph. Went 12.4 @ 125, destroying my 315-35-17 drag radials to 70mph. There was absolutely no traction below 30 mph from a roll. So I swapped to a drag pack, adjustable tq arm, adjusted my pinion angle, and instant center and went 11.5 @ 127. I have since done a couple more tweaks but the weather has not allowed me to get back out and test. I am guessing this combo has a 11.3 in it on the street. At the track, front sway bar removed, it has the potential for a 10.9 but everything will need to spot on with some good air.
At this point, I don't plan to install a cam with my 194K valve train. Sense I'm pulling heads, I don't want to miss the opportunity to upgrade to 243's for $300-$400(unported of course). Once I find heads, I plan to decide on a cam and begin gathering other components. I have to research: lifters, oil pump, inspecting rockers, timing chain or timing set. I also need to determine if I need to upgrade injectors and fuel pump.
Congrats on your start up Brian.
My alternative plan to do do TSP LS6 2.5 and a 228r package and just sell these 799's. Buying the 2.5s verses sending mine to them is nearly a wash. I considered just going with the stage 1 and using the valves in my 799's, but it sounds like the slightly larger valves give a small bump in power.
