Planning heads and cam
https://ls1tech.com/forums/multimedi...pics-vids.html
Thanks for the link.
http://www.corvetteforum.com/forums/...o-results.html
I just helped a friend swap a CamMotion 227/231 cam (very close to the cam above) in his C5. Love the power band. We did the Straub trunnion upgrade which I recommend. Morel 5315s also went in.
AI can clearance the heads for 3/8" pushrods which will likely gain a few HP up top.
I would not port the LS6 intake but would save for a FAST90 at a later time.
I'm also keeping my eye out for a deal on a Fast 90 or 92. As bad as I hate to part with more money, it makes sense to swap it while I'm there before the tune. I can port it myself.
For heads and cam, I've about decided to buy the heads and cam from the same place at the same time. I feel that buying them together will help the vendor match things up for me(CC, pushrods).
So many options with heads/cam. Still considering:
AI 226's with 224/228 .605
AI 226's with 230.238
TSP PRC 225's with 228R
TSP stg 1 with 228R
Progress since starting this thread (updated in 1st post):
- Racetronix kit installed (still need to check PSI but runs great)
- purchased Morel 5315 lifters
- purchased GTP injectors
OP, as mentioned I think the 60 ft is key for 1/4 mile times.. with my set up listed in my signature with 18" nitto nt05(not good for the track lol) I was hitting 2.2 or higher 60 ft and running high 13s at 109 because I was burning through first gear.. threw my 15" drag rims on (275/50/15 MT drag radials), removed my sway bar, and added an UD pulley.. I was cutting 1.7 60 ft and 12.1 @ 111.. I grabbed. 1.6 on one pass and hit a 12.02 but red lighted... couldn't hook the rest of the day.. all in all it shows you how much good tires make a difference.. my car has horrible suspension as well.. lowered roughly 1.8" and doesn't transfer weight at all..
I totally agree. Right there with you on mods and E/T's. I never went below 2.0 60 until I got the SS3600 and Toyo TQ's. Then it was consistent 1.70 60's running low 12's. I got a bargain on a set of Hoosier DOT's mounted on 10 spokes so traction should be good to go with more power. I have LCA's with relo's but might spring for some single adjust rears to help the 60'.
Remember, I started with "considering a cam", LOL. Now its cam, pushrods, lifters, oil pump, ported heads, dual valve springs, injectors and so on. I can't decide whether to lay down or grab an brew.
BTW, thanks for the suggestion.
