Best place to get cam spec'd
Looking to get a cam custom spec'd for my build. It's a stock bottom end 03 lq4 with stock 317 heads, will have BTR .660 springs and 7.4" pushrods, Ls6 intake, 1 truck manifold, and 1 c6 manifold to a 2 1/4" crossover up to a cast t6 s480. 96mm 1.32ar any suggestions or help would be appreciated! I'm considering BTR because that's where my current cam is from.
Old School Heavy
Hi Hater, sure there are many here that can provide a great camshaft.
I can "model" all the camshaft specs using Engine Analyizer PRO with HP/Torque at the specified areas.
You should get the Andrews file OR Cam Doctor file to be accurate.
There is NO Charge for this work.
Lance
Lance
