Why is 7 always the problem?
Old Jan 11, 2017 | 06:36 AM
  #61
ddnspider's Avatar
8Lug knows all and there is nothing to question so we can just go ahead and /Thread
Old Jan 11, 2017 | 09:21 AM
  #62
carport mechanic's Avatar
Originally Posted by 8.Lug
What? Where did you get all that from? He's a writer for Hot Rod, Motor Trend and a couple other rags. That's it. Might want to do a bit more research.
yeah I did stretch the truth a bit there in back in 2000 he worked for gm. In 03 he was in engineering for gm performance parts to help them get that all up and running good. You are talking present I'm talking past wich is more relevant to ls1 rite. Ed Korner was in charge of that other stuff. What I originally said was it helps prevent issues with 7 not completely solve the problem.
Old Jan 11, 2017 | 12:27 PM
  #63
truckdoug's Avatar
keep the jibber jabber goin it's getting good
Old Jan 11, 2017 | 01:11 PM
  #64
RockinWs6's Avatar
I talked to number 7 cylinder about this, said couldn't take it no mo................
Old Jan 11, 2017 | 02:10 PM
  #65
ddnspider's Avatar
Old Jan 11, 2017 | 02:32 PM
  #66
pantera_efi's Avatar
Default Block Core Sand
OK, YES I too agree,"keep this going"
NOW the "8's" question is an EASY answer, as I make engine blocks.
The Core Box must have support, the "green" circles, both top and bottom
The Core Sand must "flow" easily when the block is heated.
My latest direction was taken from Jim @ Racing Research.
I will call a GM engineer(ret), now a teacher @ ASU for more information on the #7 issue.
He was the TOP GM engineer on LS testing/LS program at the GM Proving Grounds.
Lance, BTW Jim placed sixty "thermo's" on the LS engine/head with no clear answer.
Old Jan 11, 2017 | 04:22 PM
  #67
lol never let the truth get in the way or a good story.
Old Jan 11, 2017 | 04:37 PM
  #68
yeah. I apologize dude. It's an interesting one a solution would be good. If cutting a head gasket works I'm all for it personally don't have enough experience to attempt it myself.
Old Jan 11, 2017 | 08:40 PM
  #69
volsfan32119's Avatar
Well lets see if I can bring this thread back to the original intent lol. I THINK I might have found the problem???
It also hurt my cylinder wall a little. On these aluminum blocks do they get bored? Resleeved? Whats the best route? Should I look for a new block?
Old Jan 11, 2017 | 08:59 PM
  #70
truckdoug's Avatar
how bad is it hurt? split liner or just a scratch?
i agree we should get back on track. i'm all for a little spirited bullshitting for the sake of bench racing but lets chill with the name calling. way too much of that snarkyness on LS1tech as of late, myself included.
Old Jan 11, 2017 | 09:14 PM
  #71
No visible cracks but not really scratched but more like a dent if that makes sense. Here's a pic. The little horizontal area is the "dent".
Old Jan 11, 2017 | 10:27 PM
  #72
wow now this is cool stuff. Will be following. Good on ya mate.
Old Jan 11, 2017 | 10:59 PM
  #73
truckdoug's Avatar
pics no worky
Old Jan 12, 2017 | 08:33 AM
  #74
Not sure what happened to the pics but here they are again.
Cylinder wall...
Old Jan 12, 2017 | 11:42 AM
  #75
Default Head Bolt Length
Again, GM states the later LS block uses EQUAL head bolt lengths to REDUCE bore distortion.
This could add to the # 7 problem.
Lance
Old Jan 13, 2017 | 12:02 PM
  #76
MuhThugga's Avatar
You can't possibly believe that GM did away with something supposedly so important just to gain like 2hp. The steam vent isn't the problem. #7 runs hot on ALL of GM's V8's, this is nothing new. The back of every engine always runs hot.
Gains were a lot more than 2 HP, but I see you know everything there is to know, so proceed.
have you read the thread at all? We're specifically talking about using the ls1 4 port crossover vs. The 2 port ls6 and blocked off rear ports. And you CAN use the 4 port on an ls6 intake you just have to be willing to shave the bottom of the intake a bit.
I have. There were no pictures of the factory piece. Now there are. You're welcome.
Old Jan 13, 2017 | 02:35 PM
  #77
truckdoug's Avatar
oof looks like that piece stuck and rocked the piston pretty good. surprised it didnt bend the rod.
you might get away with a hone. looks can be deceiving when your looking at a glossy surface from the side. i'd probably run a dingleball though there real quick so I can get a good look at it. just a passor two to take the gloss off. then check the bore for deformation with a dial bore gauge.
Old Jan 13, 2017 | 06:39 PM
  #78
It's pretty significant so I'll have to take it to the machine shop and see what they say.
