What should a GREAT LS6 S2 head flow?
Is 330cfm a good peak number @.600 on the intake side? What about 230cfm on Exhaust?
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ March 18, 2003, 06:20 PM: Message edited by: Jimmyz ]</small>
Let me know what numbers you make with the new heads and cam. My 382 is about to start getting built. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
an example:
head a flows 350cfm with a 300cc runner( not reality i know)
head b flows 300cfm with a 200cc runner
which is the better head?
the lower the intake runner volume the better it is for smaller cubic inches and or lower rpm range when you go up in runner volume you need more air to fill it so you need more rpm and cid to do that efficiently. so what i am saying is the runner volume vs the cfm is a better way of picking the "best" head for you application( rpm range, cid,etc)
Jay
<strong> With what size valves? My stage 2 5.3L flow 310 237 with 2.055 intake 1.60 exhaust valves at .600. I would say 330 intake would be a max flow rate at that .600 lift. The velocity is equally important to take into account. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would say 2.05 in. and 1.60 ex. would be about right. I figured 330cfm was a MAX number to achieve.
We should more considerate of flow numbers from .200-.500" and not worry about the peaks, because your induction system does not support those high flow numbers.
Velocity should not be hurt by larger valves, and shrouding is in Comb. chamber not really in cylinder. 10cfm is realistic but not worth trading mid lift flow for top lift flow gains.
<small>[ March 19, 2003, 09:24 PM: Message edited by: LS1derfull ]</small>
