Is this cam To big for a Driver in a 5.3?
Building a Fox body with a 5.3. This car is going to be a driver.Car will have a 4l60e. Was talking to a Erson rep at PRI last month and he sugester either of these 2 cams
230/238 .578lift 114
or
234/242 .621 lift 114
he also reccomended bee hive springs for anything under .600 lift. I thought these were a little large for stock heads and very street friendly. If not what is everyone suggestions? I have a TR224 in my vert that makes good power and has good street manners. Catch is we are an erson dealer and I can get these at a good deal. Thanks for any input
or
Both are bigger than the cam in my 383 LS1 stroker. I think both would work pretty well in a larger 6.0+ engine. Those cams might make nice race cams with a 4L60e and 4000+ stall.
I would contact other vendors for suggestions.
Driver 5.3 seems like a 224/230 at .050 cam might might work well but thats pretty aggressive.
That's what I thought as well. Too big. I think I'll go with the 224 or thunder has a 228 that looks good as well thanks for the input. What about beehives? Use them or no?
In a 5.3, absolutely keep the lift under .600 and int and exh duration absolutely no more than 235, and thats pretty high too. I find it odd that your exhaust duration is so high. Cathedrals dont need duration splits like rectangles do.
As far as springs, id say under .575 lift you could do beehive. Simply becuase the maintanence is much less on hives vs doubles. Doubles i think they say swap every 10k.
Generally more cubes means you can get away with more duration. I know stock ls1s consider anying over 235 to be a large cam, but a cam on a 416 isnt considered big until over 245
So LJMS stage 3 truck cam is to big for a stock 5.3?
Per Lil John Motorsports website:
https://www.liljohnsmotorsports.com/...camshafts.html
Truck Stage III Cam 218/224 .553"/.553" 113+3
Truck Stage IV Cam 224/230 .553"/.547" 111+2
Both the stage 3 & stage 4 cams are with in the guidelines he mentioned. They have less than 235 duration @ .050 lift and max lift less than .600
Op when i say too big im talking too big for 100+ mile a week use. Too big is almost irrelevant imo for a weekend car.
Super Hulk Smash
or
or
I would recommend something like a 222/226 114 or so with .600" lift on milder type lobes from Cam Motion, EPS, or Comp LSL and a decent dual valve spring like a PAC 1904 or BTR Platinums. Something in the 150/400lbs range with stock rockers.
Thanks for all the input. This car will see the track every once in a while but will see some miles. I told the rep I thought this cam was too much in a 5.3 with stock heads and a driver but he insisted it wasnt, Especially when I talked to other companies all day that was thinking like I was. I may go with the behives. Ive been running them on my convertable and have done well. Thanks again
too big is relative around here. MY 5.3 cam is substantially larger and makes 600 at the wheels (untuned
) With the right compression and gears anything will run. thats where the relative part comes in. I can drive a top fuel car on the street as long as it stops and idles, but for some a rough as hell cam is too much and not comfy. (wieners) 646 646 246 242 108* with around 12:1 on a stock bottom end and a 2.5 inch true duals with bullets....its violent at about 4k and pulls hard past 9k. My money is the valve train. I spent a lot of time getting the geometry right, and timing was a bit of a bitch, but not impossible. You want to turn heads and make power...go big or go home. these 5.3's love them some big cams.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
No real goals(If that makes sense) Dont want another drag car and would like to be able to hop in this one, turn on the a/c and drive it to work nearly every day. therefor fuel mileage is to be concidered. Gonna use fuel injection with either the stock truck intake or a LS6 intake. Planing on upping the compression to 11:1 minimun. Not planning on spray or turbo in the near future. Going with long tubes and a 3600ish stall so cam lope is not really an issue. 3.73 gear
LS1Tech Premium Sponsor
waltsfastz
We have dyno'd about 12 different cams on the 5.3 recently. Everything from Lower duration lower lift to higher duration Higher lift and everything in between. There are very noticeable difference where the cams pick up power throughout the band.
If you give us a call we can shoot you a dyno graph on the cam you are looking at. That way you can see exactly what your getting. This way you don't have to guess at it.
We are lucky enough to be able to test the camshafts we sell, so we know exactly what they are going to do, instead of guessing at it.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
