Camshaft overlap
Now, if you're asking about buying a new cam with a different LSA, it really depends on your goals, engine size etc, as to whether it would help. For example, if you want the motor to rev, then opening the exhaust valve later will inhibit higher RPM breathing. Or another example, if you're planning to run turbo, you want the negative overlap. Now, if it's a truck engine, you might want to delay the exhaust valve opening to maximize torque, but you'll sacrifice breathing at higher RPM to accomplish this.
I just calculated your valve events as follows (and I actually got -2 degrees overlap, not -3.5). And for ***** and giggles, I closed up the LSA to 112 hypothetically:
........115......112
IVO - 0.........0
IVC - 44........44
EVO - 54.......48
EVC - -2........4
OL.....-2........4
Under this scenario, you'd sacrifice revving, high RPM power, and street manners to gain idle chop and some midrange torque.
Now, a completely different thought experiment. Lets just look at the valve events and ignore everything else:
Your cam card......New
IVO........0............4
IVC........44..........44
EVO.......54...........54
EVC.......-2............-2
OL........-2............+2
Notice, we only changed one valve event - the IVO, which will give you more intake duration and more idle chop and actually help you rev higher without sacrificing any midrange torque. Might even help midrange torque. You's give up a little off idle, though.
Anyway, if you convert all this to cam "specs", you get this comparison:
Your cam - 224/232-115+3
Modified - 228/232-114+4
I'll say it again, we only changed one valve event, but this makes the cam spec look completely different. Using your method of just changing the LSA, you actually change 2 or even all four valve events. In reality, the cam I just made up for ***** and giggles is closer to the cam card you are looking at vs taking the existing cam and screwing with the LSA - even though the spec looks completely different.
In general, on a third gen motor, I like to keep IVC around 45 degrees and EVO around 55 degrees. Then, let your tolerance for the motor being a pain in the *** and your power goals determine the IVO, EVC, and overlap events. Now, of course that all goes out the window once you decide you want peak power at 7400 rpm, or some such thing, but with the cam you are looking at, I have to guess either its a moderate street engine or a truck engine you are looking at.
[/soapbox]
228/238-114+3
IVO - 3 BTDC
IVC - 45 ABDC
EVO - 56 BBDC
EVC - 2 ATDC
OL - 5 degrees
You should have no PTV issues. You'll need to plan on some RPM to make power with L92 heads on a 6.0. That cam will run good NA and should not hold you back when you decide to spray.
https://ls1tech.com/forums/generatio...-t-matter.html
