ARP Head Stud Problem, and Solution
Old Jan 27, 2017 | 09:26 PM
  #41
07NBSChevy's Avatar
So ARP now does not recommend using their lube on the washer and only on the bottom side of the nut?
This is my instructions from my kit that was manufactured October 2016. Like I said before, I talked to an ARP Tech over the phone and he specifically told me to Lube both sides of the washers. I took a picture of the 5/16" bolt instructions but it is the same for the 7/16" with the exception of torquing to 80 ft lbs.
Do you think that using their lube on both sides of the washers can cause the nut to back off any and loose its torque setting?
Old Jan 27, 2017 | 10:55 PM
  #42
MY_2K_Z's Avatar
Originally Posted by Pantera EFI
OK, we are now educated with respect to bolt/stud Torque Values.
I have designed head gaskets.
One method used to engineer forces was to place "paper" between the head and block/head-gasket-block.
This type of material produces color changes in the material with respect to force.
Would there be someone that would like to do that test and report to LS-1 Tech members ?
I will find the paper material.
Lance
Someone posted a picture a couple years ago of this paper your talking about and it compared the clamping force of stock head bolts, Arp studs and the 1/2 studs.
I will try to find it
Edit found it.
https://ls1tech.com/forums/forced-in...d-studs-3.html
Size:  19.3 KBName:  7E0CEFB7-7589-436C-9E60-206446FC8753_zpsagoxucwa.jpg
Size:  19.3 KBName:  5C5BA738-6D29-43A0-8209-D27DDADC8898_zpsygggtfpy.jpg
Size:  22.9 KBName:  E2F8205F-D170-44DF-A1C2-C6C970EA3EC2_zpsoedebmha.jpg
Size:  23.3 KBName:  28ED97D4-DBCA-4034-BED4-A74A8DA31634_zpsjrchysqs.jpg
Old Jan 28, 2017 | 10:19 PM
  #43
.boB's Avatar
Just thinking out loud ignore the guy talking to himself.. On a highly stressed engine,, wouldn't torquing to tension spec be better than rotational torque?
Yes, it would. But how would you measure it? It can easily be done on rod bolts, but pretty much impossible to do on head bolts.
So I struggled with this off and on over the week. Can't get the darned thing out! I tried left handed drill bits, easy outs etc.
Monday I'll take it to a machine shop and see if they can get it out. They'll probably have to use a TimeSert to repair the thread. Since I torqued down 4 other studs before this one snapped, I'll just have them TimeSert those holes in case there was any thread damage. The torque wrench clicked at 100 ft/lb's, but who knows how much torque there really was.
It really irritates me that I spend a bucket load of money for a "quality" product, and these are the results. Weeks of wasted effort and lost money.
Old Jan 28, 2017 | 10:44 PM
  #44
JakeFusion's Avatar
Super Hulk Smash
That is frustrating.
I've used ARP bolts for a while now. I would not recommend putting moly lube on both sides of the washer. It goes on the threads and on the bottom of the bolt head. You want it between the head and the top of the washer but not on the bottom. That helps with the torque reading in my experience.
Old Jan 29, 2017 | 09:48 AM
  #45
pantera_efi's Avatar
Default Oil Filter Moly
Hi, yes use oil.
My reason is different, the reason of a "plugged" Oil Filter.
The OVER use of Moly Thread Lube can cause the filter to be compacted with that debris.
Lance
Old Jan 29, 2017 | 01:39 PM
  #46
Paul Bell's Avatar
That's MISTER MODERATOR
Hi, yes use oil.
Lance
This is why us smart engine builders do a oil & filter change after first start and heat cycle.
Old Jan 29, 2017 | 02:09 PM
  #47
dallas_'s Avatar
Originally Posted by .boB
According to their tech, the lubricated washer acts like a Torrington bearing, and not a washer. That's what he told me.
Hey Bob,
Thanks for posting the info. Can you help enlighten me on what that means exactly and why it would affect the torque spec?
Old Jan 29, 2017 | 02:22 PM
  #48
Paul Bell's Avatar
Originally Posted by dallas_
Hey Bob,
You want the nut alone to turn. That way, all the twisting action goes into tensioning the bolt. It the washer turns also, some of the torque reading on your torque wrench includes what it takes to turn the washer.
 Michael S. Palmer
Old Jan 29, 2017 | 06:31 PM
  #49
.boB's Avatar
Hey Bob,
According to the tech, if the washer spins, it will act like a bearing. A bearing will spin with little resistance, even of it is very tight. So you'll crank on that nut until you finally overcome the bearing effect. Or the stud snaps, or the threads pull out. Whichever comes first.
Old Jan 30, 2017 | 11:14 AM
  #50
Marc 85Z28's Avatar
Lance
http://www.fujifilm.com/products/prescale/
