ARP Head Stud Problem, and Solution
Old Jan 23, 2017 | 04:19 PM
.boB's Avatar
Default ARP Head Stud Problem, and Solution
I'v been using ARP fasteners for many years. First time they've ever let me down.
I had planned to have the engine nearly assembled by the end of the week end. But, now I have to buy a set of bolt extractors to get the broken stud out. And I won't get replacement parts until the middle or end of the week. Maybe I can get the engine assembled next week end.
Old Jan 23, 2017 | 04:20 PM
.boB's Avatar
I'm a big believer in reading and following directions that come with the parts. So here are the directions that I followed.
- Clean the washers with solvent prior to installation.
- Make sure the aluminum head surface is thoroughly clean and free of oil
- Install the washers
- lubricate the threads of the studs and the bottom of the nuts
- Torque in three steps, with the final torque to 100 ft/lbs.
I spoke a very nice gentleman at ARP a few minutes ago. They're going to send me a new set by overnight mail. But, he said there will be new instructions. The problem is that the washers are too smooth and slippery, even if everything is cleaned well. The washer acts like a Torrington bearing, and starts to spin. The stud snaps before proper torque is reached. It's a problem on the Chevy LS and Ford Modular engines.
Currently, the answer is two fold. After cleaning the washers, rough up one side with some coarse sand paper. That side goes against the aluminum head, and shouldn't be allowed to spin. I think I'll put a paint mark on the washers so I can observe for spinning. In the future, the washers will come with a texture one side that looks like fish scales.
Second, the torque spec will be reduced from 100 ft/lbs to 80 ft/lbs.
Over the last couple of years, I'v read about people breaking an ARP stud. But this is the first time I'v heard why, and what to do about it.
Old Jan 23, 2017 | 05:05 PM
Jontall's Avatar
Are you aware that the Chinese are knocking-off ARP studs/bolts? Did you get them from eBay? They are flooding the market with counterfeit everything.
Old Jan 23, 2017 | 05:09 PM
.boB's Avatar
No, definitely from ARP, purchased from Summit Racing. I follow my own advice: Never buy cheap parts, they're too expensive.
Old Jan 23, 2017 | 09:26 PM
S10xGN's Avatar
I'd not heard this before. I always lube all sides of the washer/nut/head and torque 5x's. Never had a problem...
Old Jan 24, 2017 | 07:29 AM
KCS's Avatar
KCS
Moderator
Sounds like they made a mistake with the torque value. The washer deal sounds bogus. I bet reducing torque by 20ft-lbs helps more than anything you do with the washer.
Old Jan 24, 2017 | 09:53 AM
RonSSNova's Avatar
Specs on mine were 80 ft/lbs.
So odd that you got instructions to go to 100.
Old Jan 24, 2017 | 09:59 AM
KCS's Avatar
KCS
Moderator
That's what I was thinking. Even though it's a coyote engine, it's still an M11 fastener like the LS stuff. Unless you go to an ARP2000 material or higher, it's all 75 to 80ft-lbs.
 Michael S. Palmer
Old Jan 24, 2017 | 10:02 AM
BlackDuk98's Avatar
I have felt the washers spin on some of my studs many times over the years, but never a problem (knock on wood). Thank you for the info.
-Mark jr,
Old Jan 24, 2017 | 10:06 AM
blk94z's Avatar
Should be 75-80 FT LBS...
Old Jan 24, 2017 | 10:51 AM
.boB's Avatar
The specs were 100 ft/lbs, clearly stated in the instruction. When I talked with the rep, he told me they were changing that spec from 100 to 80 ft/lbs.
If you look up the new instructions on the ARP web site, it says 85 ft/lbs. But it doesn't say anything about roughing up the washer, just that it needs to be clean and dry, no lube between the washer and the alum head surface.
In the past, I'v always lubed both sides of the washer before installation. Even though I'v installed ARP head studs many times, I read and followed the instructions anyway.
Old Jan 24, 2017 | 10:55 AM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
ARP has been flip-flopping on torque specs and installation procedures for years. Now you have to modified the parts before install? Laughable. It seems like they have been caught up in the "only game in town" mentality, and subsequently dropped the ball. Hell, I mentioned weeks ago the difficulty I suffered trying to get ARP studs into an aluminum block LS1 because ARP choose the wrong class of bolt thread to insert into a production part, and was told to pound salt as a result.
I have decided that if it isn't my only option, I will be shopping somewhere else for my critical fasteners.
Old Jan 24, 2017 | 11:37 AM
truckdoug's Avatar
Weird, my China studs never do that.
Old Jan 24, 2017 | 11:39 AM
BlackDuk98's Avatar
That has me wondering if I was adding lube to both sides of the washer. I just cannot remember at all. I will pay more attention this spring and make sure that the back of the washer is dry and only lube the bottoms of the nut and see if I get slippage again.
Old Jan 24, 2017 | 02:38 PM
https://www.fastenal.com/content/fed...0Fasteners.pdf
You don't need ARP's approval to torque something properly.
Old Jan 24, 2017 | 03:01 PM
KCS's Avatar
KCS
Moderator
Originally Posted by mOtOrHeAd MiKe
https://www.fastenal.com/content/feds/pdf/Torque-Tension%2520Chart%2520for%2520Metric%2520Fasteners .pdf
Link isn't working. Curious what you've got there.
Old Jan 24, 2017 | 04:07 PM
truckdoug's Avatar
Probably a torque spec by bolt size/pitch chart.
Old Jan 24, 2017 | 10:02 PM
Fixed it, I was mobile and Google loves to monkey with links.
Exactly.
My point is that ARP didn't invent fastener standards, fancy lube or not; when in doubt check your sources.
Old Jan 25, 2017 | 12:12 AM
Paul Bell's Avatar
That's MISTER MODERATOR
I would NOT lube the washer on any side. The nut face gets lubed then spun onto the stud.
And yes, I'd say the 100# spec was an error.
Old Jan 25, 2017 | 07:26 AM
KCS's Avatar
KCS
Moderator
Where do you find that for an M11 bolt in a 8740 material? The chart only shows M10 and M12 up to class 12.9.
