is 420hp possible?
Old Feb 2, 2017 | 03:44 PM
jgro650's Avatar
Default is 420hp possible?
First engine build here and trying to get a realistic hp number for my build
2005 4.8 gen iii block bored over to 3.903 (346?)
TSP ls1/6 forged rotating assembly with -3.2 pistons
706 heads(not the ones that crack)
TSP torquer v2 cam kit with duals springs
truck intake
unsure of injectors size i would need
ls2 timing gear
will be behind a new t56 magnum or tko600...undecided.
I've seen so many different builds and setups that I'm unsure where I would end up. Thank you ahead of time.
IF THIS IS IN THE WRONG AREA PLEASE LET ME KNOW, STILL LEARNING THE FORUMS.
Old Feb 2, 2017 | 04:00 PM
Jtm2085's Avatar
I would get some 36lb GTP injectors. They will do 42lbs with our fuel rail pressure. Those heads with out any porting are going to kill your set up. I would look into getting a stock set of 243's if your on a budget
Old Feb 2, 2017 | 05:20 PM
jgro650's Avatar
Yea, I've been told these heads will limit the motor, i'll look into some 243's....thanks for the response. I appreciate it.
Any idea where keeping the stock 706 vs 243 would put HP?
Old Feb 2, 2017 | 06:42 PM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
So many better cam options too.
Old Feb 3, 2017 | 09:18 AM
Bspeck82's Avatar
I wouldnt get a Torquer v2 even on a stroker. (And from what I have read and the Valve events I have calculated, this cam isnt the best option for "torque" ) Ignore the cool names. If you got the truck intake and heads and a stroker, clearly this engine is set up for torque, id build for that instead of HP. Call up a good cam manufacture and have them build you a custom cam. The cam will make or break you.
Old Feb 3, 2017 | 09:39 AM
JoeNova's Avatar
Restricted User
Why dish out the money for a forged rotating assembly? Seemed like a poor investment.
Old Feb 5, 2017 | 11:16 AM
RockinWs6's Avatar
(Russian accent) 420hp possible but not recommended
Old Feb 5, 2017 | 01:33 PM
Bspeck82's Avatar
(Russian Accent) 420 horsepower can be made with alcohol injection by way of Vodka. Everyting is much better wid vodka.
Old Feb 5, 2017 | 03:27 PM
Where the heck is the "like" button in these forums? lol
Old Feb 5, 2017 | 03:30 PM
truckdoug's Avatar
(latvian accent) what about potato?
Old Feb 5, 2017 | 08:58 PM
Bspeck82's Avatar
(Russian Accent) Da! But Potato become Vodka, just like uhhh... like tomato become ketchup.
Old Feb 7, 2017 | 06:36 PM
wannafbody's Avatar
Might want to use the Dorman truck intake
