Is Corrosion around water pump seals OK?
I've been cleaning up my iron block and noticed corrosion or slight pitting around the water pump ports. Will the silicone gasket seal on this or do I need to surface it first?
That image is of the cleaned up surface, I have actually already hit it with a white roloc! I might just scrape the surface with some jbweld to fill in the pits just to be safe, that seems like cheap insurance.
Use some RTV Sealant on it instead of gaskets and it'll seal it up just fine. Let it sit for 24 hours before adding coolant and running it though. If RTV can't seal it, it won't seal. It's some good stuff.
http://www.all-spec.com/Catalog/Adhe...FURqfgoduyUMOA
He speaks the truth. We did the gaskets on my friends 6.0 iron block 2 times, with gaskets and it leaked every time. We put RTV on 2 years ago and it hasn't leaked a drop since. Just saying.
The assembly manual states explicitly not to use any sealing compound on the silicone gaskets -- not sure why but I think it must be for good reason, maybe it breaks down the gasket material? I'll tell you what though, I was glad that there was no RTV on my gaskets when I just removed and replaced the front and rear covers! I hate scraping...
Iron and aluminum have different expansion rates and that gasket will experience some movement after many years, so maybe there is a good reason for the stock gaskets, just say'n
