Need help with Cam/Heads/Stall choice (LS!)
Since then my WS6 has mostly been in storage until about a year ago.
4 months ago I bought a new '16 Z06 A8 and have been drag racing that (best of 10.39 so far), and my 17 year old son has been drag racing my old 2000 model WS6/A4.
The WS6 has been running 12.7's in good air, and 12.9-13.0's in 1500-2000DA. Well, now he's ready to go faster and I am ready to help him.
This is what the WS6 has currently:
Stainless 1.75" LT's, ORY, Borla Catback, PTB, CAI, LID, Smog delete, WS6 intake, A4 w/shift kit and Billet Servo and 4.0 Detroit Locker in a 9", 160 deg. therm., stock heads, stock cam and stock torque converter. 80K miles. 3700lbs.
I am thinking heads, camshaft and stall converter upgrades specifically for quarter mile performance, but i want to stay with the stock short block for now.
Can you guys offer some tips on a good package that would utilize the stock short block, but (goals here) drop 1 second from the 1/4 mile times. I realize this may be a very lofty goal, but that's the approximate goal for now.
Thanks!
The question is do you want the car Streetable at all?
If not, go with a CircleD 3E 4400 stall, EPS 236/248 110 Cam, and a set of TFS As Cast 220s worked by Brian Tooley. You'll be low 11s high 10s depending on what the weight ends up being and how effective you can sixty.
If you want something a little more streetable. A Yank SS4000 converter, BTR Stage 3, plus the TFS 220s and a port matched FAST102 intake manifold worked by Tooley would be nice too. The converter is worth a half a second alone. So 1 second is easy in this case.
There is definitely a means to doing the max effort SBE thing, but it requires a lot of attention to detail and planning. Lord knows I would love to do it one day.
That being said a basic H/C/I package will get you your mid-11s done. Tuning will be cruicial.
In either instance you are going to expose that 4L60e as the weak link in the car. Look at an 80e swap.
Cam - LLSR with springs, pushrods, etc
Ported MSD intake
You'll be able to get away with less cam, daily drive it, and still make great power. Or swing for the fence. If it's track only.
On a 5.7 bottom end that's going to be on the top tier of performers.
Ported MSD intake
Or he could go with a set of As Cast 220's.
s
I dropped down from a larger cam to a smaller cam and didn't lose much. Good heads make up for a lot as well. And there's very few heads for a 3.9" bore that ET like TEA LS6 heads...
Ported MSD intake
Alternatively
MMS 223 Sportsman as cast,11.0-11.5;1 Comp. Cam Motion HR 231*/237* .615"/.595" ~114*+3*,FAST 92, 90/92 TB, Stall 3600-4000.
Easy Mid to low 11s and very streetable.
He blew up the stock 4L60E. I purchased a Frank Cahall built 4L60E from a friend who was going turbo and swapping to a TH400, and it came with a 4000 nitrous ProTorque converter ($1300 total). It works beautifully, and with this lower power level is pretty tight.
Keep in mind we still have a bone stock LS1, stock heads, and stock cam, with a LS6 intake, ebay 1-3/4" LT's and a 4.0L 9" rearend.
The car is now running 12.2-12.3's in 2000-2200DA, and I expect it to run a 11.9/12.0 as-is in "great air".
Here is our next move. I bought a 40K mi. SBE LS2 shortblock that came with a ported oil pump and upgraded timing chain and a comp cams .235/.243, .621/.624 113LSA camshaft from another friend ($1500), and have purchased some refreshed As Cast 220's ($1300) (with BTR 660 springs, titanium retainers) that have been milled to 60cc chambers to use on this engine as well. The pistons are .004-.006 out of the hole, so I'm planning on running .040-.042 cometics. That should net me 6.5 cc less with this combo, and about 11.9 comp. +/- if I did my math correctly. I will put the .051's back in it if PTV is too close.
Next move, upgraded new lifters, an OTB Fast102, 92MM TB, and some ARH 1-7/8 LT's and Y-pipe that I picked up used.
I hope to have all of these installed and tuned within a couple of months and then I expect we will need a cage next!!
BTW, the car dyno'd 325RWHP/391RWTQ with the current setup on a loaded mustang dyno. I am thinking the car should pick up at least 100RWHP with this setup conservatively, and at least 1 second off of the ET.
Hope you guys feel I'm headed in the right direction with this one!
IF the cam "is way off", i would consider swapping it to something more appropriate before the engine install..???!?!?
I would suggest a VMax Velocity Ring, it is supposed to make
Tuning easier by eliminating the lip behind the 92 MM TB
at the entrance of the 102 Manifold. I am using one on my
Ported LS2 TB with my Ported FAST LS3 Intake.
Biggest difference is at low speed throttle and transition
For street driving, if track only may be little to no benefit.
