Minimum cylinder wall thickness for stroker nitrous build?
Plan on using a gen 3/4 6.0 iron block. 4" stroker kit with a G6x3 cam. Ported and polished Ls3 5364 heads with a 5 angle valve job. 102mm ls3 intake and a 102mm dual stage wet nitrous plate. The nitrous will be used with a dual stage progressive controller for a total of a 300 shot. Will also be running this motor on e85. I have everything for the engine except the pistons, and the block (maybe).
Was hoping to bore the block to 4.065 but from all the low number readings i've been gettin it seems impossible to bore these blocks at all. (Maybe i'm just having bad luck on good blocks)
So my question is what would you say the safest cylinder wall thickness would be for me to run?
The numbers you're getting are typical. Most 6.0L iron blocks I've seen can fit a 1/8" rod between the cylinders. With a 4" bore in a 4.40" bore spacing, that means there's about .140" wall left, and that's assuming its centered.
I'd just take it .005" over and run it. Going to 4.030" isn't really going to make any difference in power when you're spraying a 300 shot. The extra wall thickness might be a better advantage though.
I appreciate the reply, another opinion is always helpful.
What about gen 4 blocks? Is there any gain durability wise with them over the gen 3?
I haven't messed with too many Gen IV iron blocks, but I doubt they're much different as far as cylinder wall thickness.
https://ls1tech.com/forums/generatio...you-think.html
You'll have a 402ci motor which you not go tell the difference between a 402 vs a 408ci motor.
Please though, correct me if i'm wrong with my reasoning on the ls3 valves and larger bore size.
64post brought up a good point on the cylinder walls. After all the LQ blocks are not as strong as people think they are. They don't have siamese bores like some of the later LS blocks have.
Otherwise I would do a 402ci as I already mention. Keep all the meat you can!! Don't worry about valve shrouding with the factory bore size. If it was a serious problem GM wouldn't had put the head on the (6.0) LY6 engine to begin with...
