Cam for 5.3 on 87 octane? (L33)
http://www.lingenfelter.com/product/L210085297.html
-edit- I just found something that says the LQ cam has 5deg more duration so it may not be a downgrade. I'll look into it more.
http://www.lingenfelter.com/PDFdownloads/L210085297.pdf
Also, the low overlap would make it drive like stock. You're just using more aggressive lobes and a better profile to make more power overall. Like I said, you'd probably see about 30HP more with this cam. Which is a nice little bump considering it'd drive exactly like stock. It'd pick up over any of the GM cams I think. And if your stock springs can do 90lbs seat pressure, you can reuse them it looks like.
Edit- L33 cam specs- 193/193 @.050, lift unknown
LQ9 cam specs- 196/201 @.050, lift .467/.479
One more edit- just for comparison, LM7 cam is 191/190, .466/.479, so L33 gains 2 and 3 degrees, not much, but enough to make a slight difference.
https://www.briantooleyracing.com/tr...age-i-cam.html
https://www.briantooleyracing.com/tr...ge-ii-cam.html
And here is a Cam Motion cam... picked up 41/22:
http://store.cammotion.com/53-l-325ci-95-compression-2
https://ls1tech.com/forums/dynamomet...hp-22rwtq.html
That was a good comparison of factory cams, but also proved that the aftermarket is still the source for the best performance cams.
http://store.cammotion.com/53-l-325ci-101-compression-4
