Deck surface cleanliness
Old Apr 8, 2017 | 06:17 PM
buggy323's Avatar
Default Deck surface cleanliness
I've been working on getting the deck of my 5.3 clean and I've reached a point the I can't make anymore progress I started with plastic razor blades then once I couldn't go any further I added acetone and finished up with 1500 grit wet dry paper this is where im at currently when I run my finger across any part of the surface there aren't any raised areas and it feels perfectly flat.
Old Apr 8, 2017 | 07:09 PM
KCS's Avatar
KCS
Moderator
Looks good. I'd run it.
Old Apr 8, 2017 | 07:11 PM
buggy323's Avatar
Sweet! thanks.
Old Apr 9, 2017 | 08:39 AM
cookseyb's Avatar
Originally Posted by buggy323
Sweet! thanks.
Looks like the knock sensors might have had water intrusion on them, might want to check them and re-seal while it's handy, Deck looks good...
Old Apr 9, 2017 | 10:11 AM
buggy323's Avatar
Will do, quick question I was cleaning out the bolt holes when I came across oil in the top three large holes I have no idea how it got there but there is enough to cover the threads should I be concerned about this or should I just get them clean and dry and throw it back together?
Old Apr 9, 2017 | 10:16 AM
DietCoke's Avatar
iron block? brass wire wheel on a drill.
DietCoke's Avatar
soft or medium roloc pads also will clean it up.
Old Apr 9, 2017 | 10:31 AM
ironmanLS1's Avatar
Visually it looks good, if there are no ridges you catch with a fingernail you should be good to go. Also make sure it is flat with a known straight edge. Make sure all the threads are clean and free of debris and oil or water. Personally I don't like roloc as this fibers are very abrasive if they get down in the cylinder wall.
