cheap ebay solid lifters
Old Apr 9, 2017 | 09:31 AM
truckdoug's Avatar
Default cheap ebay solid lifters
so per our policy regarding products of non sponsors I cant post a direct link
but use this search term "GM/CHEVY LS1/LS2/LS3/LS6/LS7 ALL ELITE RACER SOLID ROLLER LIFTERS VERTICAL BAR"
and you'll see some solid roller lifters that dont look like a copy of anything I recognize.
they look like they are based on an early ls1 type hyd lifter
anyone have any experience with them?
I'm not looking to go solid roller anytime soon, just curious.
Thanks
Old Apr 10, 2017 | 12:12 PM
64post's Avatar
C.A.T technologies, $269 ......RUN AWAY
Old Apr 10, 2017 | 01:02 PM
redbird555's Avatar
Lifters are the absolute lady place I'd want to take a chance....potential to do incredible damage and a pain to replace. A good set of solid lifters isn't terrible expensive either
Old Apr 10, 2017 | 01:22 PM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
I'd do it in something I didn't care about.
Old Apr 10, 2017 | 02:01 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Morel has a set of solid roller tie bar lifters in the $350 range with a .750 wheel. You dont have to spend the moon to go solid roller. Buy off ebay you get what you pay for. Trying to get ahold of most ebay companies is difficult to begin with, but then hoping they provide tech support etc...you get the picture.
We carry ALL morel lifters. If you have any questions on them, let me know.
Old Apr 10, 2017 | 02:11 PM
JoeNova's Avatar
Restricted User
Lol. Let us know where you're getting your adjustable rocker arms for a solid roller setup.
Old Apr 10, 2017 | 02:16 PM
KCS's Avatar
KCS
Moderator
These would work:
http://www.ws6project.com/user_stor/...oducts_id=5749
Old Apr 10, 2017 | 02:23 PM
This is a lifter thread....so my statement was pointed toward lifters.
Using adj rocker arms is just one way to skin th cat so to speak. Yes the other way is a pita, but there are many people doing that as well..not just on ls.
It appears with a short search Kurt Urban uses and knows of guys that use the stock rocker. My guess would be with a modified trunion, but still stock rocker.
Or like kcs posted our link...the adj rocker arm doesnt always have to be on the pushrod cup.
Besides im sure ebay has cheap ls adj rockers also.
Old Apr 10, 2017 | 02:52 PM
.boB's Avatar
Never buy cheap parts. They're too expensive.
Old Apr 10, 2017 | 03:15 PM
JakeFusion's Avatar
Super Hulk Smash
A few guys are using stock rockers or something like YTs shimmed with the solid rollers.
I would spend the cash on the Morels. They can be had for under $400 in both the drop-in and link-bar. And for a milder solid roller... like a Cam Motion LLR... they would work fine.
If you go more extreme, you need more extreme parts like a bushed lifter with an upgraded wheel and shaft mounts.
But I wouldn't skimp and buy ebay lifters. Certain things are okay... like headers, radiators, intercoolers, or even copycat BOVs and the like. They seem to do okay for the price. When you start moving to internal engine components that rely on precision, it becomes an issue.
Old Apr 10, 2017 | 04:09 PM
truckdoug's Avatar
how expensive was that arp stud you snapped?
Old Apr 10, 2017 | 05:40 PM
99 Black Bird T/A's Avatar
Well said.
Old Apr 11, 2017 | 12:49 PM
thunderstruck507's Avatar
I have a large in depth thread on using stock rockers with shims. Car is still running that way and I've never adjusted shims since the cam was first installed.
Kinda makes it hard to justify spending the big money on rocker arms. I'm very pleased with the setup. It did take a few hours to put together but it's been zero maintenance so I can't complain.
Old Apr 11, 2017 | 12:59 PM
Shimming and pushrod length can only get you so far with rocker arm geometry on a non adj setup. Side loading the valve can be a big issue with non PM guides. Stock rockers work well that is no doubt, but everyone has their own recipe to success.
Properly designed full roller rockers can provide gains in quite a few areas.
Old Apr 11, 2017 | 04:29 PM
Also very true, can't argue with any of those points.
And aside from the geometry benefits one day I would be curious to swap on a set and see if there were any performance gains too. ~$1100 plus new valve covers is a tough pill to swallow for some of us though haha.
Old Apr 11, 2017 | 04:37 PM
Some of the gains likely cannot be normally measured. Guide wear would be one of those. Valve tip and stem wear also.
Do you mean on solid roller only? Or just a std rocker swap on a dyno?
Old Apr 11, 2017 | 06:07 PM
cookseyb's Avatar
Doug, Do you know what a Flocculator is?
Old Apr 12, 2017 | 07:23 AM
truckdoug's Avatar
yes, I build components for them some years ago.
but if there's a joke there I'd like to hear it.
Old Apr 12, 2017 | 09:59 AM
In for the joke, if any......lol
Old Apr 12, 2017 | 02:21 PM
truckdoug's Avatar
they keep wastewater at treatment plants turbulent, aka they "stir the ****" which is fair if it refers to my comment on boB's post.
but my original question is genuine. If these exist, someone is buying them. I was hoping someone had actual experience with them. I guess I'll be the guinea pig.
