Are Comp Cam Trunions ok?
Depending on the hardness depth, cam lobes & springs you might get lucky but why would you risk the outer hard layer flaking off?
It's risky because they're batch heat treated, never know how deep they're heat treated after grinding.
FWIW T&D uses case hardened shafts but are deep case hardened & have pressurized oiling.
https://m.summitracing.com/parts/sum...FJYRoCP6rw_wcB
My email response to Chris:
Chris, I got the kit yesterday. Thanks for the FAST service. Order Fri, get Tues!
Also, the kit was installed using some of the parts from the Summit caged brg tool kit. :O)
The engine is new, and has the CC brg kit in it.
I had a set of spare rockers, so your kit has been installed in them. [Ultrasonic cleaner works wonders!]
Took <1 hr to do them. Had NO bushing shavings, fitment issues.
They are going on the engine today...
The packaging was very well done, the parts were CLEAN!
I disassembled the rockers, ran them in an ultrasonic cleaner, and had cleaner than new, parts to work with.
The unused rockers w/ the CC kit installed, is for sale.
http://sdparts.com/i-24075194-sdpc-s...nnion-kit.html
