Are Comp Cam Trunions ok?
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
We should have more in stock around July. We will be offering both the TSP needle bearing trunion kits and a bushing kit. We are working with CHE to get them on board and it looks very promising. Once we have more in stock we will try to update any related threads.
Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
If they were intentionally selling a product they know will fail 100% of the time like people think, it would be more than grounds for a class action. But that in itself totally sucks becaus in class action the defendant pays out but only the lawyers really get paid. The rest is divied up amongst the many plaintiffs. Even if Judge Judy tried it.
Comp will claim they were made to replace the factory original trunion set-up. Has anybody done nothing to their engine but replace the trunions and see how they wear? Probably not because there is no need to do that.
I know I would expect something like this to last as long or longer than OEM stuff, but maybe COMP doesn't think along those lines.
1. In failure mode it will continue to get louder and louder and warn the customer something is wrong giving the owner time to get it fixed with out catastrophic failure.
2. In failure mode the LS OEM oil pump or the aftermarket stuff is not going to fail with fine bronze material passing through it. The same can not be said about OEM and aftermarket needle bearings. Once these get to the pump it is catastrophic failure.
the heat treat is too thin on the comps and they flake off. i had a complete set do it. there were 2 of 32 wear surfaces that didnt flake off into my oil.
I have no idea how comp messed up so badly, i have never heard of this problem in any other motor and roller rockers have been around longer than i have been alive, but they pulled it off.
