347 out of a 327?
Old May 17, 2017 | 06:22 PM
Krhoads1002's Avatar
Default 347 out of a 327?
Just trying to figure out what I would need to bore the engine too and what else needs done. It's a LS 5.3 going into my 92 Camaro. Thanks for the help!
Old May 17, 2017 | 06:33 PM
Bore it to stock LS1/LS6 bore size -3.898" That is actually 346 CI.
Old May 17, 2017 | 06:41 PM
cookseyb's Avatar
You do know you have to use a iron block.. Aluminum won't bore to 99MM.
Old May 17, 2017 | 06:44 PM
The Gen IV ones will.
Old May 17, 2017 | 06:46 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
We have complete kits to turn your 5.3 into a 5.7. 3.905 bore. Comes with pistons with coated skirt, plasma moky std fit rings, cam/rod/crank bearings, thrust plate, hd timing set, hi flo oil pump, full gasket set with mls head gaskets and stock head bolts for $600 shipped. summit nor jegs can beat that price. We have either press fit or floating pin, same price.
I have personally built 10 iron 5.7s. They make quite a bit of power over the reg 5.3l. Great engine.
Old May 17, 2017 | 06:52 PM
Which would you say is mostly doing the power increase, the .4L increase in displacement, or unshrouding the valves?
Old May 17, 2017 | 07:00 PM
All of it adds up. Extra cr. Cubic inch. larger bore size unshrouding valves. To say any one thing contributes more allows rise to opinions like "well just use a flat top 5.3 piston and make the same power as the larger bore". If that were true gm wouldn't use the 6.0. They would put the flat top 5.3 in 2500 trucks and 1 tons. Obviously the ones that argue that either arent privy to real engine design theory, or like to turbo jy 4.8s and 5.3s stock and show their edick off to everyone.
Old May 17, 2017 | 07:09 PM
JakeFusion's Avatar
Super Hulk Smash
The L33 Gen III aluminum block will punch out to 5.7L as well. But that's a waste of that block. It's magical for turbos.
Old May 17, 2017 | 07:11 PM
Sounds legit! Thanks again!
Old May 18, 2017 | 01:10 AM
RonSSNova's Avatar
Heck, add a 4" crank and make it a 382
Old May 18, 2017 | 01:13 AM
You cannot just add a 4inch crank. Pistons are higher, rods are higher, and the crank too. plus clearance on block. and balance of assembly.
Old May 18, 2017 | 07:34 AM
1bdbrd's Avatar
Just saw your thread about it. I will PM you.
Old May 18, 2017 | 09:58 AM
cookseyb's Avatar
Shame on me, I didn't realize there were Al. blocks that would go out b that big, learn something every day! I just got my iron block LS1 back from the machine shop yesterday, can't wait to see how it works in a 94 SWB pickup..
Old May 18, 2017 | 10:03 AM
No biggie man! The earlier blocks had thin walls and could not be bored much at all. The Gen 4 5.3 blocks I understand are based on the LS3 casting, which have thick enough cylinder walls to bore out a bit. Anyone please correct me if this is not right!
I did not know this myself until recently, so don't beat yourself up about it! lol
