Head bolt way too long
Old May 25, 2017 | 06:04 AM
  #41
98CayenneT/A's Avatar
That would be a Ls6 block. Also Ls6 block will not have the indent markings that I have identified by Green arrows on my block. Below the green dots
Old May 25, 2017 | 06:22 AM
  #42
04+ Ls used all shorter (4") head bolts
Old May 25, 2017 | 07:42 AM
  #43
moekluse's Avatar
can you confirm what block this is with these photos?
Old May 25, 2017 | 07:49 AM
  #44
I thought you had the casting number 12561168 ? Which would make it a Ls6 block. Also with all the head bolts being the 4" that makes it 04 or newer Ls6.
It also does not have the indents I pointed out in my picture that ls1 blocks have but Ls6 blocks do not, like yours.
If I had to guess I would say it absolutely is a Ls6 block from 2004 or newer.
Old May 25, 2017 | 07:53 AM
  #45
moekluse's Avatar
good to hear, thank you!
