Budget Head and Cam
So Im trying to find heads and a cam and all the parts that goes into it (springs, lifters,bolts, pushrods, etc) for around $2000-$2500 range (or less). Id like to hit 425+ whp range. I dont have an issue with porting my heads if it is a good amount cheaper than buying new. Do I need new oil pump, timing chain, injectors?
Or should I just get the 515hp trickflow package and be done with it?
Great package for a great price. All you need is a set of MLS head gaskets and a cheap cloye's LS2 chain and whatever oil pump you want, everything else TSP sets up for you to bolt on. Oh, don't forget about oil and coolant. Kinda hard to beat the 225's for the money.
this is the trickflow kit. $3300. I also have some other packages to look at but they are relatively similar in parts list but cheaper and put together by people I asked. 515fwhp is comparable to 450rwhp at best. Which would get me where is like to be I think.
We also have the oil pump, timing set etc needed to work with all that as well as gaskets and bolts.
Email me and we can work you up a total price and beat your 425 mark!
Rpmspeedtech@gmail.com
Give us a shout, We will put together the perfect package for you.
Thank you
Dustin
Thompson Motorsports
dustin@thompsonmotorsports.net
972-853-2450
Comparing straight across isnt possible for them but thats as close as it gets.
Of course someone could work the head over, but that is true on any head. Then you incur ALOT of extra cost. The tfs are stellar out of the box. No need to send them off. plus afr doesnt have a comparison for the 220 as cast tfs head.
Edit: Always call them first and see what cam they would run with their heads for your specific application and goals.
Heads are $1700
The cam is $385 and pushrods are $100
Id recommend lifters when you have heads off. They are $95, trays are 32.
Install kit runs $200.
$2500 gets you completely set up with every thing you need and a custom cam tailored for you
