Double roller chain with LS2 dampener?
Old May 31, 2017 | 12:39 AM
Don Nguyen's Avatar
Default Double roller chain with LS2 dampener?
Who here runs a double roller chain with an LS2 dampener? Maybe not necessary, but my main question is going to be if there is any interference or rubbing with running one. If there isn't, for $20 or so, it wouldn't be a bad investment I would think.
Couldn't find any really solid answers to this question from the threads I found on here.
-Don
Old May 31, 2017 | 08:36 AM
jimmyp3353's Avatar
What engine is it on? I know there are a few LS engines (LM7) that don't use any sort of dampener or tensioner at all. There are no bolt holes for one.
Old May 31, 2017 | 10:17 AM
Don Nguyen's Avatar
L33, which if I remember should have the holes. If they don't/didn't, then I would not even bother haha.
Old May 31, 2017 | 10:32 AM
pantera_efi's Avatar
Default Single Chain = Strongest
Hi Don, I am in Santa Ana, CA.
I would like to invite you to my shop to inspect MY Single Chain AND Billet Gears.
I use these only with either guide dampener both LS-2 and L-92 VVT.
Jimmy, I have drilled some blocks for the guide, the ones with bosses present.
I ALWAYS fit the guide.
Lance
Old May 31, 2017 | 11:19 AM
jimmyp3353's Avatar
Lance
I have an LM7 right now that has no guide and no holes. I want to run a guide. What do you recommend?
Old Jun 1, 2017 | 10:12 AM
64post's Avatar
I've retro fit them to iron 6.0 blocks using a transfer punch, 17/64 drill with collar, M8x1.25 tap punch and shop vac after careful placement, it's not difficult, measure twice before tapping your punch. Did not use double roller chains.
Old Jun 1, 2017 | 10:29 AM
Default Chain Guide Boss
Hi "64", good tech.
I too use your method AND have found the Boss Flats on the blocks.
So I ask you, Jimmy, does your block have the "flats" ?
Lance
Old Jun 4, 2017 | 05:20 AM
07NBSChevy's Avatar
I read somewhere on one of these forums that someone makes a thicker damper for use with double roller chains, would make since so the entire section width of the chain(s) can make contact with the damper. Most of the time I don't see a damper used with Double Roller chains, even tho I would prefer to use something.
Can anyone confirm if there is a thicker damper for use with double roller chains?
Old Jun 4, 2017 | 10:35 AM
speedtigger's Avatar
Old School Heavy
If you want to use the LS2 style damper on a block that has no mounting holes, simply use this adapter:
http://store.cammotion.com/mobile/trick-flow-ls2-style-timing-chain-damper-kit
Old Jun 5, 2017 | 10:44 AM
64post's Avatar
http://store.cammotion.com/mobile/tr...ain-damper-kit
Or, save the $44 and drill and tap. Some skill required.
Old Jun 5, 2017 | 10:49 AM
Don Nguyen's Avatar
So is it still possible or ideal to run a damper with a double roller chain set up?
Old Jun 5, 2017 | 01:17 PM
JakeFusion's Avatar
Super Hulk Smash
I have had the Katech LS6 damper in my car, but took it off when I swapped cams. I was running a Rollmaster Double Roller.
It's not needed with a double chain but necessary with a single. The single whips around and can break. The double has no slack in it.
When I took it apart, there was zero witness marks on the damper. And the double roller was still impossibly tight.
Old Jun 5, 2017 | 01:55 PM
Old School Heavy
The dampers have the ability to dampen harmonics. Both loose and tight chains regardless of being single row or double row will still have harmonics. A tighter chain will behave differently, but it still has harmonics. I run them any time that it is possible.
Old Jun 5, 2017 | 05:17 PM
JakeFusion's Avatar
Super Hulk Smash
I read something, maybe from Cloyes, that advised against it. But I initially ran it that way.
But I had to remove my oil pump to swap cams because of it. So I was in no mood to mess with it when I reassembled.
