So I dropped a lifter and would like some advice from here (pics inside)
I got everything torn down and it seems like the only things damaged are the cam, lifter bore, and the piston walls are scratched a bit (that I'll chalk up to use since the car has ~200k).
My question is, what would you guys do at this point? I'm trying to stay on a budget with this. Wondering if I can get away with having a shop bore/clean the block and getting a new cam and pistons.. The cam IS irrecoverable, right?
Can shops usually clean up lifter bores?
Car is an 01 WS6 Trans Am fwiw.
Pics
http://imgur.com/a/OrVkB
(Edited so you don't have to scroll past so many pics)
Pics
