Cam
Old Jun 13, 2017 | 02:04 PM
gyrene2003's Avatar
Default Cam
Gotta replace cam, dropped lifter. Took lobe out. Messaged a vendor. Didn't get response, average time from order to when shipped on cams, as an example, off the shelf grind from TSP? Just in a tight spot. Need to get car up. Soon as I get funds I'll be ordering
Old Jun 13, 2017 | 02:13 PM
Docrocket1967's Avatar
Everytime I have ever ordered from them I got my cam usually within a week. You could overnight it im sure for the extra cost. Call them and see what they say
Old Jun 13, 2017 | 02:25 PM
gyrene2003's Avatar
Yeah. Just being lazy
Old Jun 13, 2017 | 02:53 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
What cam are you looking for?
Old Jun 13, 2017 | 03:34 PM
gyrene2003's Avatar
I've run an F13 from futral and an MS3 from Texas speed. MS3 cam was in the car when I bought it. Good cam, all good supporting mods, but it looks like bad install or shorty job. Maybe pushrod length was wrong. Anyway, this is a screw off car. Make noise and cruise around, was going to give the MS4 a whirl. My f13 took afew weeks from futral. Just wondering if it was going to be the same again.
Old Jun 13, 2017 | 03:41 PM
Ms4 will be fine just make sure you have a 3.73+ (recommended 3.90 or higher) gear really and 3400+ stall if auto.
Old Jun 13, 2017 | 03:44 PM
Bspeck82's Avatar
Perhaps look at streetsweeper ht?
Old Jun 14, 2017 | 08:40 AM
Ive been a bit disappointed with the MS3 cam myself, but i had such high hopes too
Old Jun 14, 2017 | 09:45 AM
jimmyp3353's Avatar
More than half the time I message a vendor on this site it takes forever. One of them even replied to my message a month after the fact. I will tell you though that WS6Store is spot on with replying to messages. Customer service is second to none. On a different note, I run the MS3 cam right now on my dedicated drag car which has an LM7 (I know, I know, not optimal with a 5.3)and the thing rips, mostly because I have a TH350, 4.10 gear, and a 4400 stall. It's really only temporary since the custom nitrous grind I had failed within a month, and I had this laying around so I put it in while I am waiting for a new one.
Old Jun 14, 2017 | 10:19 AM
gyrene2003's Avatar
Thanks. Yeah I gotcha. I just put in a fresh set of 3.73s. Car has an edge racing 3600 stall. It was in the car already. Personally I only buy yank. I'll be going back to the SS4000, might even try out the pt series stalls this time
Old Jun 14, 2017 | 10:22 AM
HCI2000SS's Avatar
On my LQ9 I run a cam almost identical to the MS3, and with 4.10's and a 6-speed I wouldn't want any bigger. So on a LS1 I'd think a 4.10 gear minimum (on a manual) and a 3.73 at minimum for the auto with a 4000 stall
Old Jun 14, 2017 | 10:24 AM
gyrene2003's Avatar
I'll get all the parts I need. Eventually. Money permitting. I was looking at the other series to try something like a 4200 stall. I've run 3.73s, 3.90s and 4.10s in an auto before. I'd rather go bigger on the stall than the gears this time.
Old Jun 14, 2017 | 11:18 AM
You would prob have more fun with a smaller cam that is less like a 3500rpm light switch, since youre losing rpm per gear with 3.73s and that cams actual power band. Tsp has some brand new designs that use their new lobes that make good power. It may not sound the same, but itll drive better and have less issues and prob be more fun to drive. a 231/236 they have would be just as fun imo and not feel so dogged under 4k.
Old Jun 14, 2017 | 11:21 AM
Thanks for the kind words.
