How free should cam spin?
The old cam spun very easily, but that was a stock cam with 170k on it. It's since had new bearings installed.
I can spin the cam by hand, it doesn't feel like anything is binding necessarily, just takes some effort (more effort than the crank did). I'll pull the cam and see if there are any wear marks on it or the bearings.
Lastly if the shop that did your block machine work didn't acid dip it (and very few do anymore) then they most likely baked and tumbled it. The shot blasting procedure causes machined edges to flatten or mushroom (main bores, lifter bores, and you guessed it CAM bores)
Mains typically get a quick line hone, lifter bores get dressed with a small brake cylinder hone but few shops will hone the cam tunnel. So when the new bearings get installed there is undue pressure or pinching which when combined with a brand new cam will cause it to turn tighter than it should. Will it be OK?? Perhaps but IMO it should be super easy and basically done RIGHT !!!!!
To be honest I think it's just the assembly lube. It doesn't feel like I'm fighting a mechanical issue, it just feels sticky lol.
BTW, how do you guys measure the rear-most bearings with the crank/rods in the motor? I had the foresight to measure them before I installed anything, but with the way my stand is set up i can't get my gauge in there to measure if cranking the mains down made any changes.
