LM7 Loud Bottom End Noise (VIDEO)
I am working on a LM7 Swap into a 91 Volvo 240. When I fire it up there are loud noises that seem to come from the bottom of the engine/flywheel area. It flanks like there are rocks in the oil pan. It also will fall on its face and not go above 4000ish when revved.
It is a stock LM7 with stock 2001 silverado harness and ECU connected to a 4l60e. It does not have the O2 sensors hooked up but otherwise it should be functional (emissions also removed).
Anybody recognise this noise? Sounds pretty bad. I'm guessing it'll have to come back out for a tear down. It does not seem to be exhaust banging against something, but rather something internal. Clanging quiets down/goes away when revved or under load.
VIDEO:
VIDEO:
The reason it won't rev is this noise is picked up by the knock sensors and the computer is pulling timing, sounds like the exhaust rattle and maybe the flex plate with those goofy GM fasteners isn't tight
Thanks for the tips. Hopefully you guys are right. I have to pull the oil pan off anyway as it is only about 2" off the ground and will rub under moderate braking :/ so I'll take a look at the flex plate then.
https://ls1tech.com/forums/conversio...-oil-pans.html
I pulled the trans yesterday. You guys have a good ear. Flex plate bolts were loose. I guess that's what I get for assuming they were tight on a junkyard engine. Now I can fix the atf leak while I'm at it
