Another Oil Pressure Question
Ok this is what i have, this is a fresh build, LQ9 block, standard crank, rods and wiseco pistons, machine shop checked the crank and all it needed was polishing, they supplied the bearings, all standard size, it has a pump from Precision oil pumps, the medium volume version, double row chain with the oil pump spacers, Cam Motion solid roller cam with Morel 4737 lifters, Cold start idle oil pressure is at 45-50, fully warmed up < about 205 engine temp, oil pressure is at 32-35, the problem comes when the rpm's are raised, the oil pressure might go up 5 pounds at the most, just stays at 32-35, this is what i done so far, pulled the pan, checked the pickup 0 ring, it had a small section on it that looked like it had rolled and pinched a little bit, removed the oil pump and timing chain, installed a new cam retainer, pan had some small metal particles in it, then i saw where the pump was rubbing the timing chain even with the spacers, so I'm guessing thats where the metal came from,, clearanced the pump then completely dissembled the pump to check for a possible stuck relief valve, found nothing wrong with it, installed the pump, sealed the pump spacer plates, while the pan was off i can see that the rear barbell was in place, put everything back together, might have gained a few pounds more but the pressure still does not rise with rpm's, before i pull the engine, Advise needed...., I'm also feeding a S480 turbo from the plate on side the pan thru a 6AN hose, no restrictor. HELP
