LM7 Daily Driver Build
· Full rebuild using a WS6Store LS Engine Complete Rebuild Kit
· WS6Store High Lift Hot Cam w/ PAC 1218 Beehive Springs & Chromoly Pushrods
· Straub Bushing Trunion Upgrade
· LS7 Lifters
· GM FlexFuel Injectors
· Reuse the stock truck 3-Bolt Intake and port the stock 78mm TB
· Either ported 862 Heads (what are on the engine) or ported 243/799's
· Bore to 3.898 to make an iron 346
· Mid-Length Headers (I would go with long tubes, but the truck is lowered 4-6 and ground clearance is an issue)
· Cold Air Intake (obligatory)
I am shooting for 425 horsepower at the crank. (I think this is possible)
I have some questions though.
· Can all 5.3 iron blocks safely be bored to 3.898 or will I need to have the block sonic tested to be sure?
· Tech@WS6Store: is the rebuild kit available with flat top pistons instead of a stock style dish? Upcharge for this?
· Is there any real advantage to buying a set of 243 or 799 heads over using the 862 heads that I have now once ported? I know that the 862 has a smaller intake valve as well as a smaller chamber. Can they be made to flow as well as the better castings or are they just junk?
· Will the FlexFuel injectors do what I want them to and be easy for the tuner to work with, or would I be better off buying something like the 36lb FAST injectors?
I have just started disassembling the engine and plan to update this thread with photos along the way...I always enjoy reading well documented build threads from guys like of JakeFusion and Darth_V8r, so here is mine. It's not for an F-body, but this is by far the premier LS engine forum on the internet so I hope my build is welcome here.
This is the truck the engine will be in.
Those wheels look good (and the truck does too) what are those?
With a cam and some headwork even minor 425 should be no problem
Our 3.898 and 3.908 pistons are flat top.
The flex fuel inj are easiest to tune and work with your factory connector so i would use them. The tables are as easy as copy from flex fuel tune and paste into yours for the 5 to 8 parameters needed
The 243 or 799s will flow better already and need only a good valve job even to make am better.
Ported its no contest, but do you really need it? That part is up to you!
Imo the 862 will do what you want in ported form.
Engine on the stand, ready for disassembly.
Inside the knock sensor holes, yucky. The plugs were very brittle as well, both of those broke in the removal process.
Knock sensor out, I guess I won't be reusing these. Notice the standing water still in the hole.
Second hole, no better than the first.
The goop that fell into the valley from this, also I am beginning to notice that the previous owner of this engine did not change the oil every 3,000 miles.
This is why regularly scheduled oil changes are important.
Intake, valley cover, valve covers, and most of the accessories removed.
I am using this empty roll cart I had to store and organize the parts as they come out.
It's definitely a 5.3 now. The cylinder walls look excellent, and the piston tops aren't that bad at all either.
Other side also looks good. A couple of the lifters were very hard to remove though.
This engine has sat a couple of years in the shop, with the oil drained, but fully assembled. look at the fuzzy goop formed on the counterweights. I'm not sure how that was possible, but it shouldn't hurt anything.
We have new knock sensor harnesses on hand also ;-)
I have heard that you should never replace the cam bearings in an LS engine, because they are installed from the factory and then line honed through the bearings, so therefore the actual block's cam bore isn't necessarily straight, and upon installation of a new bearing in the bore, it will eat the new bearings nearly immediately.
The cleaning process would necessitate new cam bearings.
Does that mean that I will just need to get the block line honed before putting new cam bearings in? Or what should I do?
