Cam for Daily
Thanks!
They are made for 2 separate reasons.
The high lift hot cam is more of an entry level style where they want a good bump in power but maybe have an auto and want to use the stock stall and gears. Or they want a super easy daily driver for a manual trans. Its range is roughly 2k and up.
The high lift asa requires a stall and gears are recommended. Due in part to the overlap but also the mid range duration. You will lose a little bottom end just putting it in to an all stock ls1 but it makes up for that mostly in mid range and top end, sounds very aggressive, and is a great overall cam. But its range is more 3k and above.
If you are chasing numbers with cams you arent going to get the best cam for you is what I think. The number shouldn't matter (within reason of course). The way the cam performs overall in more than just power should be the way to choose one.
Trying to compare a 218/227 to a 230s cam or larger just isnt realistic at all.
