Is the 224r cam outdated?
Old Jul 26, 2017 | 12:07 AM
98 4mula's Avatar
Default Is the 224r cam outdated?
I picked up a used 224r for a project I'm working on with trick flow heads. I've read online that it's an old dinosaur and would leave too much hp/tq on the table if compared to the newer dual pattern cams. Should I sell it and pick up something more current. The engine is an LQ4 6.0 with the truck intake
Old Jul 26, 2017 | 12:46 AM
07NBSChevy's Avatar
I wouldn't consider it outdated, it is used very often and popular. The design is a bit older tho and you will gain more with a custom split pattern cam. It is the go to cam for a Daily driver LS1/LS6 that is easy on the valve train, it is proven and works well. I do not know if TSP updated the lobes when they stopped using COMP cam cores.
I recently had a custom spec'd cam for a customer LQ4. He used it for towing and daily driver. It was basically stock other than an intake kit, longtubes, and a tune. The cam was a 224/230 .598/.598 on a 112 LSA using BTR .660 Platinum Springs. Customer will be dynoing the truck soon so we will see how much power it makes. Truck runs great and pulls hard from 2,400 up.
With Trickflow heads, I would go with a split pattern cam, just my opinion.
Old Jul 26, 2017 | 03:33 AM
HCI2000SS's Avatar
Which TF heads do you have and what vehicle is it going in?
Old Jul 26, 2017 | 09:26 AM
98 4mula's Avatar
The veh is a 69 f100 shortbed with a 4l60e and a 3500 converter. The heads are the trick flow 215 cathedrals
Old Jul 26, 2017 | 09:47 AM
farmington's Avatar
what gear?
Old Jul 26, 2017 | 10:46 AM
98 4mula's Avatar
Stock gear for now, 3.0x's. will end up with 3.73 most likely. Will be used as a truck from time to time with a couple track days and not a DD
Old Jul 26, 2017 | 10:48 AM
98 4mula's Avatar
Not looking for max performance,I don't mind leaving a little hp on the table since I already have the cam. I just read multiple post that the 224r was outdated
Old Jul 26, 2017 | 10:51 AM
thunderstruck507's Avatar
TSP redesigned their cams so to answer your question no it is not outdated. Also depends how new your used one is.
That said I seem to remember the Trick Flow heads liking something weird (I want to say they like the close intake/exhaust durations). For those heads I would definitely call and speak to someone and get something optimized for the heads.
No point running a set of killer aftermarket castings and then sticking a used cam in the engine without making sure it will be close to optimal IMO.
If you were just popping a cam in a junkyard motor with stock heads or some 243s I would say go for it.
Old Jul 26, 2017 | 09:17 PM
Tang2's Avatar
You may really like that 224 cam in a heavy truck. It'll provide a lot more low end torque than some bigger options out there, and will still carry some great HP up top. Very well balanced cam, especially for heavier vehicles.
Old Jul 26, 2017 | 10:58 PM
brandon6.0's Avatar
yea the 224 is a really nice well rounded cam. I have one in the tbss and drive it daily. Still using it with the stock 80e converter without any issues. Drives like stock with plenty power. The plus benefit is the torque a smaller cam makes which a truck or suv needs. I like it!
Old Jul 27, 2017 | 10:01 AM
wannafbody's Avatar
I think the 224/228 cam would be better.
Old Jul 27, 2017 | 06:43 PM
98 4mula's Avatar
Thanks for the responses.
Old Jul 28, 2017 | 03:06 PM
00pooterSS's Avatar
If you have the money to spend you can do better (by getting a cam spec'd to your specific setup), but in no way is it a "bad" cam. Better than the OE cam, and with more money you can do better. Up to you where you want to land in that.
Old Jul 28, 2017 | 03:54 PM
If you gotta buy a cam anyway, some cam makers will even do a custom grind for no extra charge. Win-win...
Old Jul 28, 2017 | 10:52 PM
98 4mula's Avatar
I'm just going to run the 224r that I have. Why is the .600 lift rarely used with the 224r? I notice most use .581
Old Jul 30, 2017 | 07:34 AM
01ssreda4's Avatar
224r is complete junk. I will take it off your hands for $50.
Old Jul 30, 2017 | 08:14 AM
farmington's Avatar
maybe you shouldn't be asking if its outdated, maybe you should be asking how good of a cam it is to still being used for such a long time.
Old Jul 31, 2017 | 01:25 PM
98 4mula's Avatar
How great is the 224r cam?
Old Jul 31, 2017 | 01:42 PM
HCI2000SS's Avatar
In what way do you mean how great is it?
Old Jul 31, 2017 | 03:15 PM
smokeshow's Avatar
The cam is outdated if its rusty from sitting in a humid garage. Otherwise, a piece of steel doesn't become outdated. It isn't software. It's the optimal cam for some combination of engine hardware and RPM requirements, the question is does your engine have that combination of hardware? If an arbitrary cam profile is considered outdated compared to something more modern in the same engine with same requirements, then either they got it wrong with the old cam or they got it wrong with the new cam. But neither one becomes outdated. They're just more optimized or less optimized for a given engine.
