Streetsweeper HT vs Torquer V2 or... ??
Any decent tuner should be able to get a ~228/232 112+4 to drive fine.
I would add the CamMotion Titan4 to the mix.
http://store.cammotion.com/the-titan4
I would also consider an EPS cam. I and many on here prefer CamMotion or vendors who use CamMotion over Comp.
You may want to google the EPS 222/226 cam.
Are you on stock gears?
I pocket blended and milled my 241s .030", lapped in some hollow LS6 valves(no fancy valve job) and with Lunati dual springs and Chinese long tubes it went 11.87@119.85 on the factory clutch/3.42 gears and MT drag radials
Not great but decent IMO. Did average thirty plus mpgs though
The good:
It certainly has excellent street manners. Power range is broad. No cam surge no matter what I tried which is a big improvement over the previous cam. Valvetrain is quieter although I also added a Trunion upgrade and measured pushrods which may have helped there. It has minimal lope, not undetectable as I expected from something with -10 overlap but pretty good.
The bad:
I was a little surprised how much power I dropped over my current cam. Went from a custom 216/220 .600 .600 112 Comp to this Cam Motion TT 218/226 .595 .587 116. Other than the cam change it was the same combo including ported 241s and all the usual bolt ons. Dropped about 23 rwhp. I expected to drop a bit but not that much. This cam doesn't have the same "put you in your seat" feeling of the other cam, it feels more like a stocker where it builds power. Still moves though.
