Ls1 with 243 heads/ls6 cam
Jason
You can go quite far NA. Depends on what you're wanting to spend. Easiest to just put the LS6 hardware in a boost it to 500.
If you truly want 500 rear wheel NA, it's both difficult and expensive on a 5.7L. There is a handful of us that have done it
I would have a Cam Spec'd by one of our Sponsors or choose an aftermarket off the shelf cam over using a GM OEM Cam, especially if you are looking for 500 rwhp. The 243 heads are definitely the right choice if your looking for more usable power. Having the heads milled to bring you to 11:1+ Compression will give you a nice bump in power as well.
500 rwhp is around 570-590 Hp at the crank. As mentioned above by Darth, it can get expensive.
How I would do it is;
- TSP-PRC Stage 2.5 243 heads, mill them to put you at 11:1 Compression
- Custom Spec'd/Off-The-Shelf Cam using a Cam Motion 8620 Core (Example: TSP Torquer V2 232/234 .600/.660 112+2 LSA)
- BTR .660 Platinum Spring kit
- LS7 Lifters
- Tick Performance 5/16" x .105 Wall Pushrods
- Stock Rockers with CHE Bronze Bushings
- Cometic 3.910" Bore, 0.040" Thickness Head Gasket (Measure Piston out of Hole first to determine proper head gasket thickness for 0.035"-0.040" Quench
- LS6 intake
- 90mm Throttle Body
- 1-7/8" x 3" Longtubes with free flowing Cat-Back
- LS2 Timing Set with Dampener
- Melling 10295 Oil Pump
- ATI Damper
This setup will put you in the mid/high 400 rwhp Range. You Could always go more compression, Fully CNC'd Heads, LSXR Intake, but that is when it starts to get pricey like mentioned. Now, just my opinion on how I would do it on a budget.
- LS7 Lifters
- LS6 intake
- ATI Damper
If you want dependable 500 rwhp, out of a 346, it'll cost you. Either through a great FI kit or tremendous head cam intake. Lots of cheap turbo kits, but you want dependability.
I'm all NA personally. But if you're already considering boost, bolt the LS6 stuff on and boost it. LS6 cam is a good boost cam. Ported heads will do wonders for a boosted motor too. You'll make more power with less boost.
Jason
But it seems id have to go big cam and heads which hurt drivability. Plus the price was like the same. Thank you guys for sharing with me. Like I said I'm a noob at ls motors atm. But I'm learning fast.
