Pease help with crank case problem VIDEO
Old Aug 8, 2017 | 08:59 PM
ptindall's Avatar
Default Pease help with crank case problem VIDEO
Recent engine rebuild. Keeps blowing oil from the rear main seal. Left gauge is connected to the valley port. Right gauge is T-ed into the line between the valve cover and and throttle body. As you can see it builds pressure at high RPM at part throttle and sometimes at full throttle. Need to understand what is happening and why. Crank case is vented with pictured Mighty Mouse system. Thanks for helping.
Old Aug 9, 2017 | 12:50 AM
Jontall's Avatar
Maybe this will help, because I really can't see everything that's going on: http://ls1howto.com/index.php?article=18
Old Aug 9, 2017 | 01:25 AM
ptindall's Avatar
My engine is an LS6 so it already has the valley cover port. That's what the left, white faced gauge is plugged into in the video. The large catch can you see in the pic is open to atmosphere through the large hose at the top. I am using a hose instead of a filter because this is a track car so I want to avoid any possibility of oil blowing through the filter onto the headers. This system should flow much more volume than a stock LS6 PCV system in your link. I think my problem is actually ring flutter but that seems to be a rare problem so I want to be sure before tearing the engine down and also learn why its occurring so as to be sure to avoid it next time. I've heard there are some real LS engine experts on this site. I'm hoping to hear from some who have seen this before and understand it.
Old Aug 9, 2017 | 01:21 PM
ptindall's Avatar
Nobody? If this isn't the forum to find guys with LS engine experience, which other forum should I try? Thanks.
Old Aug 9, 2017 | 01:24 PM
RockinWs6's Avatar
What do you want to know? The video is about worthless.
Old Aug 9, 2017 | 02:26 PM
ptindall's Avatar
I want to know why my crankcase is pressurizing and how to fix it. The video shows under what conditions it builds pressure, how fast it builds it, and how fast it drops. It should be very useful for understanding what is going on.
Old Aug 9, 2017 | 06:12 PM
Dragls's Avatar
Have you done a leak down test?
If not do one.
Old Aug 9, 2017 | 06:59 PM
slogo's Avatar
You might try Yellow Bullet . com
This used to be a good place, now days its more of what cam and heads do i use,
and a know it all Vendor who ****** up most threads trying to push Cheap
Chinese crap on everybody. And that probably lost the interest of a lot of people, and they don't post in here anymore.
Old Aug 9, 2017 | 07:45 PM
ptindall's Avatar
If not do one.
Yes, all cylinders leak down fine.
Old Aug 9, 2017 | 07:46 PM
ptindall's Avatar
That's a shame. Thanks for the post.
Old Aug 9, 2017 | 08:29 PM
99blkfrc99's Avatar
Maybe try shifting and not driving all around in second gear...
Old Aug 9, 2017 | 09:50 PM
ptindall's Avatar
You must be a rocket scientist.
Old Aug 9, 2017 | 10:04 PM
2xLS1's Avatar
LOLz on the vendor part. Was wondering if I was the only one who thought that.
Old Aug 10, 2017 | 01:40 AM
SoFla01SSLookinstok's Avatar
Watching your vid & looking at your pic I'll make a guess. First off I find it odd it creates the pressures intermittently. Also your leak down test being good. From the picture the routing of the system looks useless. A vented catch can from the intake manifold to the pass. side valve cover. The clean air line 6 inches away. So any vacuum that is pulled just sucks from the clean air line. Anyway the thought I have is the valve in the catch can may be malfunctioning? Keeping it from venting. Maybe try another setup/routing see if things change. Just a thought. Good luck.
Old Aug 10, 2017 | 04:23 AM
SlasherVRGR's Avatar
Is the oil being pushed out smelling of exhaust and or gas? Seems like a ring sealing issue, unless maybe the pcv ports on the valley cover and valve covers are clogged. It doesn't make sense that you'd get pressure built up from anywhere else.
Old Aug 10, 2017 | 11:20 AM
This does interest me a bit. I know every motor is different. So just for reference. I've been driving around for over a year w/ vacuum pump & vacuum gauge connected to drivers valve cover. No matter the rpm I always see crankcase pressure, vacuum drop, relevant to throttle position. WOT making the biggest drop. Saying there is always an amount of blow by during throttle.
The times when you are getting crank case pressure looks more normal to me. As to when you make WOT pulls & the gauge is solid as a rock at zero. Like said it interests me.
The little I know about ring flutter is that a big part of it can be just from driving styles. I think most likely high rpm/low throttle. Along with other things.
Ring flutter may be. When you get this taken care of please update with what you find.
Old Aug 11, 2017 | 02:44 PM
ddnspider's Avatar
You're not alone....
Old Aug 13, 2017 | 09:48 AM
ptindall's Avatar
I ran one more test with the car. I routed the catch can vent into the car where I could hold it while I drive to make sure its working and to feel how much volume its venting. It blows a lot of air and that's just the excess that isn't going back into the intake. High RPM, part throttle is what gets it going and then if I increase throttle while its blowing then it really blows. Ring flutter is also my best guess. I decided to tear the engine back down. I'm part way through getting it out of the car right now. I will update the thread when I have an answer.
If this were just a street car, yes, I could easily just drive in a manner to not induce this condition. In fact, I would probably never know the condition exists. But the primary use of this car is a track car and high rpm and varying throttle is not something you can reasonably avoid.
Old Aug 13, 2017 | 04:26 PM
kingtal0n's Avatar
My name is Jordan and I am a PCV freak. I spend more time on my PCV system design than anything else, because to me it is more important and essential to long-lived street cars than anything else. And before you ask, yes filtration (air filter, oil filters) are part of the pcv system.
If you wanted to make absolutely sure the system was plumbing correctly, you could do a boost leak test to simulate compression-blowby into the crankcase (by slightly pressurizing the crankcase) and I Would do this simultaneously with the top-end pressure test (for a complete survey/picture of the pcv system). In other words, when the rings pass 'pressurized exhaust gas' into the crankcase, this generates the +0.01PSI you see on the gauge (since you are not FI). Where that pressure goes, how the engine handles it, is up to you. For example right now you say it is passing out the rear main. Well, that is because you are containing it, or rather, trying to contain it, within the crankcase. Whatever route you have that is setup to relief the pressure- isn't working- or the pressure would stay near 0.01psi and no higher. Unless it was an obscene amount of air molecules.
more details;
Pressurize the plumbing with compression air so that you have simulated boost in the intake manifold. I have a valve on my boost leak tester device that allows me to set a constant pressure-flow, usually I start around 5psi. This would be fine for your test.
Now that the intake manifold has 5psi in it, you should have 0psi in the crankcase still. If you see anything in there you have a bad checkvalve or incorrect route somewhere already, assuming you blocked off that one line that leads from the throttle body to the crankcase (you can see it in the picture) which was the original blow-by relief from the factory. This is the first essential step to testing a pcv system because it ensures pcv valve function correctly and eliminates any possible vacuum leaks/hoses tied to the intake air system.
Once you verify that pressure in the intake != pressure in the crankcase in the above steps, I would then turn the engine over manually with a socket, go through all 8 cylinders (360* times 2) to ensure that as each intake valve opens, that 5psi is presented to the cylinder, which is sealed up nicely, so you still see 0psi in the crankcase. If the pressure rises while you spin the motor slowly it means you have a missing part of a piston ring or piston.
Now, you are ready for the final test. Remember that hose from the throttle body that leads to the valve cover? Allow approx 1-2psi into the crankcase through that hose into the crankcase. No more than 2psi max. Does the crankcase hold the pressure? If it does, you may find the rear main start to leak when this pressure is applied. If it does NOT hold pressure you have another hole somewhere that crankcase pressure is leaving from- if you find that, it is likely a high chance to be your problem. My theory is that your rear crankcase evacuation port (LS6 cover) Is somehow interfering with the front cover evacuation, perhaps plumbed wrong through the checkvalves. I hope you know the LS6 cover is not a PCV valve, it does not have a check valve. It needs a check valve on it, just like the valve cover does on the intake manifold suction side. So if running the PCV valve in the valve cover, you would also need a PCV valve between the LS6 cover and the evacuation route
On the other hand, if you note the pressure isn't leaking anywhere else, then the evacuation route is simply too small. There is no limitation to the size of the evac. i.e. I guarantee you that even if the engine had terrible blow-by conditions, you could make a hole big enough to relief the pressure (and probably a lot of oil) but I digress
If you would like me to more thoroughly detail how I would run the hoses please feel free to ask, and there are good pics online elsewhere on the forum already
Old Aug 14, 2017 | 09:43 AM
ptindall's Avatar
more details;
Thank you for your time and effort. I cannot run your tests at this point as my engine is sitting on the ground right now. My system does not have PCV valves. There are no check valves. I am interested in why you think they are necessary in a naturally aspirated engine. Please elaborate on that. I realize that I could simply weld a couple bungs in the valve covers the size of sewer pipes and flow all the blow by I have or I could install a vacuum pump. Unfortunately this would just be a band aid. The system I have should flow more than enough air if my engine were healthy, but its not. I'm going after the root cause here as painful as it is.
