finding 11/32 pushrods
Pictured next to a 5/16 regular magnum pr for reference.
There are a few tests showing 3/8 .080 have less flex than 5/16 .120 wall then there are tests showing the opposite It also depends on length as well as material used, and any taper, as well as valvespring pressures/control.
It gets pretty deep not in just what is learned but what is argued.
For 99% of builds 5/16 080 chrome moly will work. for the rest 11/32 080 or 120. A small percentage would need anything over that. Even so they have to have a small ball end on them for both rockers and pushrod cups.
Any tests showing that a 5/16 0.120 wall is stiffer than a 3/8 0.080 wall pushrod of the same length is incorrect. The 3/8" pushrod will be 85% stiffer. Length will have an effect on stiffness, however assuming that one is comparing pushrods for the same motor then the same length would be required.
With aftermarket springs, the 5/16" will flex at high RPM and I would recommend the largest OD pushrod that will fit. Double taper pushrods can fit where a straight pushrod may not, however they tend to cost more.
Using hardened pushrods makes no difference at all with regards to stiffness.
Read this >>>>>>>> An Investigation Into Pushrod Stiffness
Note that one of the members from Sweden did some testing and his results and my analytical results were within 1%. Also, I have had several engine builders contact me after I posted that thread and tell me they find the same type of results on the dyno.
Length does affect stiffness, but most of ours are ~7.4". Certainly as you go longer, increasing OD makes even more sense.
Yup, spring rate, spring rate, spring rate. Not only that, but multiply your spring rate by the rocker ratio. Oh, and on the power stroke when you're opening the exhaust valve, add the cylinder pressure times exhaust valve area. Easy to get well past 2000 lbs being supported by a pushrod.
And hardened rods do NOT change the modulus. They only make the rods stay on the modulus longer. In other words, the yield strength is higher, but the modulus of elasticity is exactly the same.
