finding 11/32 pushrods
Old Aug 22, 2017 | 09:58 AM
  #41
vettenuts's Avatar
And bending stiffness if a function of the fourth power of OD and ID, not a squared power. The area will aid with compression stiffness, but this is likely not an issue since the weakest link is bending.
Old Aug 22, 2017 | 11:25 AM
  #42
Darth_V8r's Avatar
Moderator
Yeah, area won't actually impact the stiffness at all in terms of psi. But it will improve the load required to make it bend Generally, in our internal low cycle fatigue testing of steel bars, we see at low levels of compression that the compression modulus is virtually identical to the tensile modulus, at least until the bar bends so significantly it's ridiculous. I'd post a video, but I'm not allowed to.
It's really cool you knew about the fourth power vs the second power. We've seen that even on concrete. The code calculations all use the square root of the compression strength, but empirically, we've seen it correlates better to fourth power. Although, good luck changing the codes, right?
Old Aug 22, 2017 | 04:33 PM
  #43
DietCoke's Avatar
Originally Posted by JimMueller
What orifice size did you use on the restrictors?
.060
Though their regular PRs are already a smaller oil hole then the comps.
Old Aug 22, 2017 | 08:19 PM
  #44
joecar's Avatar
Good scientific/engineering thread
