Cam selection for 4.8 build
I am wanting a cam that would give me good down low and midrange power.
I know limited information on how cams work, what would a 201/209 601/603- 110 feel like in a 4.8 efi with 3:42 built 4l60e?
Using a longer runner truck intake would help with what you want, then you can run a larger cam and still have what you want without going above 6k too much.
Along the specs he said Id recommend the tsp stg3 truck cam
Itll work exactly how you want (cut on a 110) we have it right now for $389 shipped.
Use the pac1218 to keep it on budget.
A bit smaller the high lift stg2 is what youd want. good mild torquey cam with a max rpm what you are looking for.
