Cam for 1500HD
Recently we took a trip to the Lake of the Ozarks and it was the first long distance trip pulling the boat with the new truck. While it accelerates fine, and has no trouble moving the boat, it lacks power in the midrange and didn't want to stay in OD running 70-75 mph. I dropped it down into the 3rd to keep it from hunting but running close to 3,000 RPM got to be a little annoying. It also averaged less than 8 mpg towing it both ways. Didn't matter if I left it in OD or 3rd, it got about the same MPG.
With that being said, I am wanting to give the truck a little more power with maybe a slight improvement in MPG if possible. Right now the truck has been tuned via HPTuners, and while it made a difference in power, I still think it needs more.
I have been eyeing the Cam Motion "Drop-In Cams" but am open to other suggestions as well. This one in particular is the one I am considering.
http://store.cammotion.com/60l-truck...-compression-2
The truck has 3.73's, and slightly bigger than stock tires. I plan to do E-Fans, switch out the muffler, and possibly LT's later on down the road. Other than that I don't want to touch the truck.
Anyone with experience in cam'ing a tow vehicle I am interested in hearing your thoughts and results.
Thanks.
The electric fans will help as well. Hot Rod's engine masters show recently did a comparison of a clutch type fan to electric on a mild 350 and the results were drastic. Has me eyeballing the electric fan swap for my truck. IIRC it was over 25 hp loss with the clutch fan.
The fans would help but not nearly as much at 2200-3000 as they would at 6000.
I have the exact same truck and have the exact same trouble pulling a 24 foot enclosed. Barely pulls in od and pulls easy but revs a lot in 3rd. It is my opinion (and nobody seems to agree) that GM should have used the ls1 heads on these heavy trucks instead of 317 heads. I think they would make more torque at 2200 rpm where we need it.
A tune will help ALOT and the tsp high lift stg2 cam would fit your setup with no issues.
Add in a spectre cai and have a great hauling truck.
The efans will need a new alternator, wide radiator (if you don't already have) and a 160 tstat. I like to add in the engine oil cooler also if yours does not have one.
We can get you a complete package deal for all the parts if youd like.
The E-Fans will happen for sure as I have a nice set of Fbody fans in my basement.
As it sits, I know the truck will do well with my Camaro on an open trailer. I don't ever have plans of an enclosed trailer either.
I also plan to buy a cheap beater for DD duty to keep this truck out of the Iowa winters so the MPG isn't a huge concern. I knew going in it wouldn't be great but I expected better than 12-13 mpg unloaded and better than 8 towing. Some of the guys on Facebook and other forums claiming they get 13 towing, and 16-18 unloaded are flat out crazy. I baby this thing and it doesn't like to pass gas stations. At first, I was regretting not buying a diesel but I got this truck for about 10 grand less than what I could have got a clean diesel for with higher miles. This thing came from Kentucky and is pretty much spotless.
The ls6 springs are a great investment for about $60.
If you do want to add more lift Cam Motion can grind you a version that way.
A 370 is in the future for all 3 trucks of mine.
Ls6 springs are ok, but ive had issues with them on my own personal truck so id recommend pac1218s.
Do you have any before and after results with a cheap CAI like the Spectre? From what I have seen CAI's don't do much on these trucks other than make noise.
Also, I was under the impression that an upgraded alternator and radiator wasn't 100% necessary. We did E-Fans on my buddies 2003 RCSB truck and he had no issues with the smaller stock radiator and alt.
I'll keep you guys in mind though. I've bought a lot of stuff from Mike over the years.
I'd also like to keep running the 89 octane I currently am.
The drop in cam route sounds like it's up your alley based on what you are wanting. I kept stock pushrods and everything with mine. Just popped in the cam and put on the GM springs and retuned. Picked up 40rwhp peak but seat of the pants says it gained everywhere...the lowest dyno pull we did was down around the 2000rpm range and it was already making more power than stock. Not sure if you have seen my thread on that in the dyno section or not but it has all the details I can't remember off hand.
The gm efans will not fit with the narrow rad. ls1 fans will but why not increase cooling capacity and have exact stock fit if you can?
If you dont have at least the 140amp alt youll need it. Esp when the fans kick on at idle. 04 escalade.
Ive tried it every way on all 3 trucks. That is the best way. I am hard on my trucks, tow alot, and run the miles up.
I do not have dyno results. I would not out them on all 3 of my trucks if they did no good. I go on dirt and caliche roada alot and in fields. zero issues. I have personal mpg and butt dyno gains. Considerable to say te least on every truck and mine are all 2500 hd 4x4s. one 5spd. one 4l80. one 6l90.
If it didnt work i wouldnt use it and sure wouldnt recommend to customers.
Whatever cam you run, do yourself a favor and run the pac1218s.
I have seen your thread and am very impressed with your results. Anything over 65 mph and my truck is already at 2000 rpm so more power in that range would be great. I will more than likely get ahold of Cam Motion here soon and talk to them about it as well. It does sound like the cam I linked would be right up my alley though.
You're talking about the CAI picking up MPG and power? I mean it certainly can't hurt and I will probably do one when I have everything out for the cam install.
I appreciate all the help and insight.
http://www.cammotion.com/camshafts/t...204-212-116-4/
This version of this camshaft uses the stock valve springs. We also have a higher lift version (.550") that uses either the GM performance valve springs, or our .570" lift valve springs which are also very economical:
http://www.cammotion.com/valve-train...ve-spring-set/
Let me know if you have any questions or need help ordering.
Thanx,
Steven
FYI I average 16mpg in my crew cab 1500hd and 12mpg pulling my trailer
Why use the fbody fans when the truck fans drop in with zero issue with the larger rad? both bolt directly in and fit without any issues or modification. Having a new radiator never hurts and the added capacity helps quite a bit esp towing and hauling.
Thanx,
Steven
Appreciate your help.
Like i said if you have the smaller alt then upgrade. if you don't then obviously you do not have to.
