Cam for 5400lb truck
Old Sep 14, 2017 | 04:20 PM
Bspeck82's Avatar
Default Cam for 5400lb truck
Looking to tear into a 5.3 in a truck that weights more than a couple tons. Just looking to add some character to it, wake it up. While retaining the ability to haul around our real muscle cars. It will be accompanied by stock 799s heads, longtubes and full exhaust with a stall converter. The usual basics. Any recommendations on a cam? I need as much torque as possible from around idle on up. Dont care what it revs too. Dont care how it sounds.
Old Sep 14, 2017 | 04:23 PM
00pooterSS's Avatar
Check out the drop in truck cams. They are built for what you're looking for and retain stock pushrods and valve springs.
If you're handy pull the heads (unless you mean they'll already be off) and mill them a little too for a little more low end, efficiency, torque, power etc and to get back some of the dynamic compression you'll lose with the cam.
Old Sep 14, 2017 | 04:40 PM
Dragls's Avatar
How dare you say that on LS1tech!
Old Sep 14, 2017 | 05:00 PM
slogo's Avatar
http://sdparts.com/i-22100614-sdpc-s...0-525-115.html
don't know if scoggin and dickey are vendors or not. if not google sd0053
Old Sep 14, 2017 | 05:19 PM
BudRacing's Avatar
What stall converter are you going with?
Old Sep 14, 2017 | 06:59 PM
1FastBrick's Avatar
FYI, Yes SDPC is a sponsor on this board.
Old Sep 14, 2017 | 07:05 PM
00pooterSS's Avatar
Good one. Requires LS6 springs and last time I looked them up at scoggin dickey they were only about $70
Old Sep 14, 2017 | 08:21 PM
I would go a bit stouter than LS6 springs, like a PAC 1218 (I THINK that's it..) . Call it life insurance for your valvetrain...
Old Sep 15, 2017 | 10:28 AM
BudRacing's Avatar
LS6 springs are perfectly fine for a NA engine with mild lift under .59X". Their lower seat pressure will be better for noise and valvetrain wear.
Old Sep 15, 2017 | 11:57 AM
Bspeck82's Avatar
The entire valvetrain minus rockers will be changed. I will run high lift springs, probably duals. As for the converter it will be a circle D budget truck converter.
Old Sep 15, 2017 | 01:14 PM
00pooterSS's Avatar
Dual springs/high pressure springs is just more parasitic drain and more wear and tear if they aren't necessary. That's not really an area where overkill is better.
Old Sep 15, 2017 | 03:11 PM
I was under the (possibly mistaken) impression that LS6 springs were only good for .550 or slightly above, but not approaching .600.
Old Sep 15, 2017 | 03:39 PM
BudRacing's Avatar
The LS6 cam itself is 0.551" / 0.547" int/exh lift. There is some headroom there, but as it is .55X" of lift is plenty given proper duration. The reported cases I've seen were all for lift above .6XX". For the intended purpose of this truck cam, there is no need for lift above .6XX".
Old Sep 15, 2017 | 04:08 PM
Darth_V8r's Avatar
Moderator
Your best play might actually be some rockers. Put a set of 1.85's or such on there to gain the lift and cylinder pressure. That would give it some more pop ont he exhaust note without sacrificing any off idle torques. Less invasive, too
Old Sep 15, 2017 | 05:37 PM
00pooterSS's Avatar
You are correct, thing is the "truck" cams range from around .500-.55x IIRC, with most being under .550
Agreed
I never considered rockers only, have you seen any literature with results from rockers only I could read on? Or know someone that's tried it? Curious how they liked it, especially if they did it on a truck.
Old Sep 15, 2017 | 06:01 PM
One other thing I forgot to mention was that LS6 springs were a bit "soft" for the application, with the result that some knowledgeable people don't even like them much in their intended application. BUT this might just be "internet rhetoric"....
Old Sep 15, 2017 | 07:15 PM
Darth_V8r's Avatar
Moderator
Most of the rockers only stuff I've seen was all tq gains. Like 8/18 hp/tq. Trucks like high idle vacuum for good off idle torque. A simple rocker upgrade won't affect that. Might even improve it
Old Sep 16, 2017 | 04:17 PM
BudRacing's Avatar
If you spend a lot of time above 5k rpm, then that's fair to say. Most street cars don't see this kind of use, especially trucks. The LS6 valvetrain was designed for spirited street use with track capabilities. There is some trade-off to be said about springs that are too snappy on an already noisy LS valvetrain, including extra stress on lifters. The latest LS6 springs, IMO, provide a happy medium of driveability and performance with little compromise. For racing applications, a custom valvetrain is prescribed.
Old Sep 16, 2017 | 06:13 PM
OK, thanks for clarifying!
Old Sep 17, 2017 | 09:38 AM
Bspeck82's Avatar
What lobes are recommended for heavy truck applications with torque and durability in mind?
