Daily driver torque monster
For a cam, look at the truck cams from either(or both) Texas Speed and Performance or Cam Motion. The milder ones will idle smoothly while still building up the torque a good amount.
Stay away from rectangular port heads (L92, LS3, L99, etc.) as the large ports kill off low end torque. Ported 243's or aftermarket cathedral port heads like Air Flow Research will do you a better job with low end torque, and still deliver good power up top.
A stock converter will be fine too. Higher stall speeds make the engine wind up too much.
The 408 will make torque. You can do 243 heads on the cheap if you want. I do lean to aftermarket, but depends on your budget.
A 227/235 cam will work well with about 11.5:1 compression. You'll have plenty of torque.
If you want to rev it, think more 232/240 or similar to help it breathe. Maybe even bigger, honestly. And use the L92 heads instead of 243.
Depends on your goals. Since you stated torque, use the smaller cam
https://www.summitracing.com/parts/nal-19260100
