Free 5.3L LS
get 2x 5.3 engines, both stock. The second engine is either a spare longblock or for spare parts. The Iron 5.3 is great for boost but kind of heavy for just a regular naturally aspirated car @ 400 horsepower. You lose some power because of the extra weight, and the loss of 0.4L of displacement (vs an aluminum 5.7L) together they add up. I'd rather have an aluminum 5.7L @ 380horsepower than a 5.3 @ 400 horsepower if I was never planning to go beyond 400 (no boost or nitrous)
get the right transmission from the beginning (whatever you want) because th350 'conversion' parts and a good converter will set you back too much to be worthwhile in the long run (better just get the right thing now) since you can't re-use the converter on a 4l80e or a 6-speed, which are more ideal (the 6 speed being the most). Some may tell you just use a cheaper converter; I am here to say that the converter is the heart of the car. Without an amazing converter the automatic will never truly perform the way it was meant to. I'd rather have a 6-speed than any automatic with a poor converter.
Fuel injection with these engines is terrific and easy, please check out lt1swap.com they have wiring diagrams etc... For example I pulled a 411 ECU (flex fuel) from a Tahoe in the junkyard with harness for $130, which is alot cheaper than a new stand-alone harness. Then I tuned it with HPtuners which is also cheaper than a stand-alone and works with many OEM ecu (in case you change computers or something later) Low power tunes (400~ or less like you want) are super easy because there is no fudge factoring with the injector sizes (like having to do airmass calculations to correct the computer's behavior for idle or shifting).
5.3 are very cheap, almost free. They also make an aluminum 5.3 called "L33". Ideally if you were set on using the free iron 5.3 engine, You could get it all setup then swap it out later for the L33 which would exactly fall into it's place. That is my plan I intend to use on my car also, since I'd rather "test" a cheap iron motor and "figure it all out" then go for the expensive engine later.
Finally here is a thread I made about my adventure learning about the 5.3
It will show you many of the details you might be concerned about, and I posted some valuable FSM diagrams as well.
https://ls1tech.com/forums/generatio...x-details.html
If the pictures still work that is. Photobucket did something recently to the pictures, I never paid them a dime so they shouldn't work, but somehow or other they seem to be working for me still? Let me know if you can't see the pictures there I have them all backedup.
to answer your question directly: yes I think if you are new to the engine in any way shape or form, to get everything as a bundle from somebody who puts together bundles for a living every day.
One of the major issues I keep seeing with engine "mods" is the cam bearings can walk, and many of the sufferers have had new cam bearings installed by a machine shop prior. If you plan to do the cam install yourself I would recommend avoiding machine work at all costs. I don't know how much you've done in the past but also keep in mind the engine needs to say surgically clean inside if it is open. And should never be left open for long, exposed to air. Get in and get out.
