243 heads on a 408 stroker lq4? And question about compression
Would the 243 Heads be okay on a 408 stroker I'm looking for a lot of bottom end torque ill end up putting a level 2 performabuilt behind it it also has 4.10s in the back its a 2001 Silverado 1500,
How high can I go on the compression and still run 85 octane?
If trying to run 85-88 octane theres no need for 243/799 heads. Youll need to keep compression down so just use the 317's that were on the 6.0. The 317's and 243/799' share the same intake and exhaust port but 243/799 have 64cc chambers and 317 have 72cc chambers.
So in Utah yall have a option to run water for gas ?
Moderator
Received 1,838 Likes
The mean elevation for the entire state of Utah is 6100 ft per Wikipedia:
https://en.wikipedia.org/wiki/List_o...s_by_elevation
That said I'd still run 91 in any application where you're trying to make power.
