0.041" headgaskets with 243 heads and LQ4
I stumbled upon a thread where a reputable name on here suggesting to skip milling when doing a 243/799 head swap but to go with a 0.041" thickness headgasket instead on a 6.0 lq4. Has this been done successfully with no intake manifold seating issues or other unmentioned issues? The lq4 is a 2005 in case that matters for the piston being used.
Thanks
Thanks
I recently built my engine in exactly that manner. I have a LQ4 block that we bored .030" over, put in flat top pistons, and I'm running 799 heads with Cometic .041" gaskets.
I also had my block surface decked to square it up. Not sure what my final compression ratio will be but the heads came in at 64.4CC's average.
I have not bolted on my intake manifold yet but I'm not expecting any issues with gasket seal/alignment.
All good, I just wonder why lots of people say to stay away from Cometic, but you having no issues is good to hear. Cometic has lots of options to fine tune the HG dimensions like a 4.00 bore diameter with a 0.36" compressed thickness, also available in 0.040" and 0.041"....I do like that selection as the best I could find on the Felpro headgaskets to what I would like is a 4.045" bore diameter and 0.048" compressed thickness
Going to go with a 0.010" mill and the cometic C5751-040 mls head gasket with 4.060" bore diameter and 0.040" thick. That should either put me at a CR of 10.36 or 10.7 depending on who you ask. I've never copper coated gaskets but I'll try that if it doesn't alter the thickness.
