LT4 Rods in LQ9 Build
Old Oct 24, 2017 | 12:54 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
I would have no issue with either but the scat and eagle both use an arp 7/16 rod bolt also not an M9.
Old Oct 24, 2017 | 12:55 PM
I would have no issue with either but the scat and eagle both use an arp 7/16 rod bolt also not an M9. And the odd bearing tangs wont allow any aftermarket bearing yet and of course they are only 6.100 and .945 pin so limited there as well.
Old Oct 24, 2017 | 01:43 PM
Lawhead's Avatar
The Junkyard dog series Wiesco has would work if you planned on a stock rod stock crank deal plus the ones you seem to find on EBay have coated bearings already
Don't spin it to 8k and you'll be fine as far as rod bolts and any further than that
Eagle or scat wouldn't even be in the running for a rod I'd choose
Old Jul 21, 2024 | 12:20 PM
N/atahoemonster's Avatar
Originally Posted by tech@WS6store
Gm rod bearings are $20 per set so make sure you have ~$160 in the budget for rod bearings.
Afaik they arent available in the aftermarket yet but I’ll check.
Do you have a part number for these rod bearings ? I can’t find them anywhere
Old Jul 21, 2024 | 04:17 PM
See your GM dealer. If he can't help nobody can.
You do realize you're replying to a 6-year old thread, right?
