Cylinder Head Upgrades on a Budget
I sent the heads off to my local machine shop and had the heads cleaned, milled, and the valve job cut for larger 2.00" intake valves and the stock 1.55" exhaust valves. They only skim cut the deck so the compression should be about 9.5:1 on the 4.8L. They look a lot better now.
So far, I have a whopping $330 invested.
The intake port is at 2.35sq in while the exhaust is 1.37sq in. I'll be opening the intake up to about 2.54sq in and the exhaust to about 1.52sq in.
On edit, is it me, or did they even get a little bowl work done in there while they were at it?
